Neck lights
nicks78camaro
Pittsburgh, PA
Auto techs, do you find yourself using any neck lights and if so do you like them in an automotive garage setting?
I see the Snap On one that looks similar to the EZ Red one that can be a neck light or hat light.
DAWrench
Central AR
I had one didn't like it as much as a head lamp, getting it to point where you are looking is a pain.
Same problem I have with them. My electrician friend thinks they are the greatest thing ever but working on electrical panel directly in front of you is way different that automotive work.
darkzero
SoCal
At I work I mainly use neck lights, almost all of us at work do.
The Snap-on looks similar to EZ-RED cause it's made by EZ-RED, so are the Matcos, Cat, Kobalt, Realtree, ChrisFix, etc. Cause EZ-RED still holds the patent.
Here's my preferences. I use an Icon puck light as a supplement when needed. I'm not a fan of headlamps or stick lights.
Chipm
Georgia
I use EZ Red all day every day. As mentioned, if you're looking into a narrow space it is often misaligned. In that case I just put them around my ears for a minute, but 95% they are around my neck. As others mentioned, I supplement with a stick light or similar.
mreisner
North of Detroit
Only turn wrenches for fun.
Have the EZ-Red neck light and it was okay, but when it was around my neck I found my head would get in the way of the light beam. To fix this I started wearing it like a headband, but it would fall off a lot.
Then got the Snap On ECHDF042 High-Tech Headlamp and I love this thing, hands down the best headlamp out there.
I had the same experience, love the snap on one that I have now works great with glasses.
N
nicks78camaro
Pittsburgh, PA
Thank you that's the one I saw somewhere on social media. You prevented me from buying the wrong one.
Skyman
Central Maryland
