Need a 3/8 Flex Ratchet
Kilgore Trout
Northern Virginia
So I think I need a 3/8 flex ratchet to replace the starter on my Protege5. My standard ratchets are Wright Contour grips (which I really like), but it looks like the head on the wright flex ratchets might be a bit thick.
If I can get a US made one for a reasonable price, I am down for that. Though, I'd prefer not to shell out $100 for a snap-on. The Armstrong MAXX get rave reviews. Are the current $70 ebay prices jacked up due to the supply problems or is that normal?
Alternatively I could just go $20 at HF and be done with it. If I go non-US, I will probably just go with HF.
In short, I am looking for good US suggestions ($50ish would be awesome) or a thumbs-up/down for the HF.
quickstang87
I have both the snap on flex head and Harbor freight flex head. I use the snap on at work and the Harbor freight at home. They are both the "comfort grip"
The harbor freight one is a little more spongy when I really crank on something, but besides that, it seems to be a great ratchet.
For home use, I would recommend harbor freight all day long!
mach158
Marion, IA
Look at SK. I have the flexhead and has been problem free and US made. Can be found on e-bay for a decent price if you don't want to buy new.
Sent from my SM-G900R4 using Tapatalk
bwringer
Indianapolis
firworks
IL
I've got the whole fleet of HF Pittsburgh Pro flex head ratchets. They're solid performers. I abused the 1/2" one really badly one time and it held up. I basically had to use it as a breaker bar on something I couldn't get off with the M18 2763 High Power Impact because of the angle and needing to use a U-Joint. The head has gone floppy now but I fixed it with a shim.
lukedwag
The HF is OK. I have one in my service truck cause it's cheap enough to be OK losing or breaking. I really like my gear wrench one though. Long, thin. Easy to clean and lube for
T45
Definitely set a budget, and then a size.
300mm is a good size for a specialist, long ratchet
250mm is nice and sort of good everyday use size.
In addition to HF and GW, I'd consider Carlyle from Napa. They are on sale often + have local support.
PJNJ
Iowa
I have the Armstrong locking flex 88 tooth and it's become my current favorite.
Epsteins has it for $61.50 -
http://www.harryepstein.com/index.php/3-8-drive-armstrong-flex-ratchet-88-tooth.html
Tooltopia has it for $60.11 -
http://www.tooltopia.com/armstrong-...PiuGkFvqns3tOwA9GsFUlJcYEeCNmD4b1QaAqsm8P8HAQ
I also have the Gearwrench long comfort handle 120xp and it is also very good.
Amazon has the two piece set (1/4 and 3/8). I bought that set and the 1/4 is a very good long handle 1/4 flex ratchet. The price is $57.99 with free shipping and it's a killer deal. For some reason Amazon lowers the two piece set price a couple of times a year to a price lower than just the single 3/8. And right now it's lower. The 1/4 could be helpful in tight locations when changing a starter.
Here's a link -
https://www.amazon.com/dp/B00BTEXUY4/?tag=atomicindus08-20
And that NAPA Carlyle ratchet looks like a great deal too.
:beer:
Loren871
If your not wanting to spend money on snap on id definitely consider the Gearwrench 120xp. Has a thin head like your wantin and will pull nuts and bolts out of the tightest spots with its low arc swing. Can get a 4 piece set with 1/2,3/8,1/4 and a 3/8 flex stubby for around 110-120. If you just wanted the 3/8 I think there around 30-40. I have the 4 piece set and really like um. Especially the 3/8 stubby. That thing alone was worth the 110 I spent.
oldldh
Fairhope, AL
The Gearwrench 4 pc 120 tooth Flexhead Ratchet Set is a screaming deal...
I love mine...
www.tooldiscounter.com GearWrench #81230P for $94.83 + Frt...
Amazon...Prime --- $120.86...
1/2" -- 3/8" -- 1/4" and 3/8" drive stubby...
If all you need is the long 3/8"...GW #81215P is $34.92 + Frt from www.tooldiscounter.com ...
Amazon...Prime --- $51.07...
Any of these will float your boat...
Fedwrench
Valley of the sun
If you need a thin head flex head ratchet, I would recommend an 84 tooth Gearwrench flex head ratchet. Another option would be the new Home Depot husky 100 position 3/8 drive flex head ratchet. As others have mentioned, Carlyle sold by NAPA has some excellent 90 tooth flex head ratchets too.
There's always used snap on FLF80 on eBay if you can find a deal. Good luck in your quest. :beer:
used. Ebay. best deals this last week (most recent listings first.) US made. no "thin head" models in this bunch.
Blackhawk 34935 3/8" drive RHFT flex-head ratchet
used
$25.00 + $6.00 shipping "buy now"
http://www.ebay.com/itm/Blackhawk-3...:g:u9EAAOSwRgJXhXwW&item=232010915544&vxp=mtr
Champion CT405 "Plugmaster" 3/8" drive RHFT flex-head ratchet
used
$25.00 + $7.45 shipping "buy now"
http://www.ebay.com/itm/Vintage-Cha...:g:9mAAAOSw0kNXhUd4&item=131875820046&vxp=mtr
PROTO 5257 3/8" drive RHFT flex-head ratchet
used
$28.00 + $8.50 shipping "buy now"
http://www.ebay.com/itm/Proto-5257-...:g:ms4AAOSwyDxXhYgI&item=252459279619&vxp=mtr
PROTO 5257A 3/8" drive RHFT flex-head ratchet quick-release w/thumbwheel
used. excellent.
$39.99 incl. shipping OBO "buy now"
http://www.ebay.com/itm/Proto-Profe...:g:mCYAAOSwc1FXazBz&item=252459411776&vxp=mtr
New Britain NB54 3/8" drive flex-head ratchet and four Blackhawk deep-well sockets
used. dirty. cheap.
$8.00 + $6.80 shipping now. 0 bids now. ends Mon. 07/18
http://www.ebay.com/itm/New-britain...:g:mIwAAOSw2zlXhDEs&item=252458142357&vxp=mtr
used
$19.99 + $6.45 shipping now. 0 bids now. ends Sat. 07/16
http://www.ebay.com/itm/Proto-5257A...:g:XekAAOSwAPlXgRhH&item=172268571667&vxp=mtr
S-K 3870 3/8" drive RHFT pivot-head ratchet
used
$18.00 + $6.80 shipping now. 4 bids now. ends Sat. 07/16
http://www.ebay.com/itm/S-k-ratchet...:g:zqYAAOSwanRXgXhY&item=252455765671&vxp=mtr
Thorsen 88JNR 3/8" drive RHFT flex-head ratchet
used
$14.99 + $7.45 shipping now. 0 bids now. ends Sat. 07/16
http://www.ebay.com/itm/Thorsen-3-8...603519?hash=item51e7b2c43f:g:wXwAAOSwoJZXSiBY
Champion CT451 3/8" drive "Plugmaster" RHFT flex-head bent handle ratchet
well used.
$13.51 + $3.65 shipping now. 3 bids now. ends Thurs. 07/14
http://www.ebay.com/itm/Vintage-CHA...547923?hash=item41ae347613:g:gi8AAOSwddNXgRJP
S-K 45178 3/8" drive RHFT flex-head "stubby" ratchet
used
$12.72 + $6.00 shipping now. 7 bids now. ends Fri. 07/15
http://www.ebay.com/itm/SK-45178-3-...:g:9dUAAOSw4dtXgEHi&item=272301437351&vxp=mtr
Banshee365
If you want USA then I would go SK for sure. But, I'll vouch for the Gearwrench 120XP as well. The flex is detected but the ratcheting mechanism is rather awesome. I've put some pretty insane torque on mine over the years and it's never stripped or skipped a single tooth. It's solid as a rock. I would probably chose the SK, however, due to their commitment to USA production. They're also near releasing a new line of ratchets so that is also something to look forward to. I would stay away from Armstrong as their future is uncertain.
SK or Gearwrench 120XP!
pjw1326
Northern Ireland
I would recommend GearWrench. I use the older 84T full polish flex head on a daily basis and can't fault it. I would be hard on tools working on trucks / HGV's.
Love the Snap On flex heads...just couldn't justify the extra premium at the time.
Know Wosad
The best bang for the buck and has a small head-fine tooth is the J5257F Proto-Facom
It's about $45 at Zoro. In all reality it's one of the best of any 3/8 flex at any price.
M6erfan
'Merica!
Just ordered one of these from Zoro with the 25% off deal. Great ratchets.
I have an older Facom version of that wrench. I think you'll like it, it's very smooth and the palm control is unique & functional. Enjoy
K
Kilgore Trout
Northern Virginia
The starter on a P5 is not easy to reach unfortunately. I haven't had to replace mine yet thankfully.
Yeah, I noticed. According to the service manual if you remove the battery and the air intake you should be able to reach the bolts. However, I have seen some posts online that say you have to move a support bracket from underneath. I am trying to avoid that problem.
dnschmidt
Phoenix, AZ
William Tool makes most of the ratchets for most of the better Taiwanese companies including TOPTUL so many of them are identical. They are a quality manufacturer. I don't know where HF is getting their new professional line, but, it's not William Tool. That stated the new HF seems very good except for the floppy head syndrome and I like the feel of the TOPTUL better and the head stays none-floppy longer. One of the differences is that the TOPTUL uses a fairly thick pin (looks to be about 1/8" solid steel) to hold the head to the fork whereas others use a tiny screw, which is too small to pull together the fork anyway. People think this screw can adjust the floppiness and that's not true. Bear down on this screw and you'll strip the threads every time.
K
Kilgore Trout
Northern Virginia
So I picked up what appears to be an almost new Proto Professional USA flex head from ebay for $35 shipped. We will see how it looks. Thanks for the help! I'll post when it arrives sometime next week.
2ndGearRubber
Pittsburgh
Gearwrench, armstrong, matco. The 84/88 ratchets are great. Slim head and body, fine teeth, and a low-profile locking mech. They're strong too, it's really gold-standard in my eyes when it comes to commonly available ratchets, when access is a concern. Personally, I fell the Armstrong is the best of the 3, with the most ergonomic and thin of the handles. I don't do comfort grips; they take up too much space, and get nasty.
If your goal is for space constraints, 84/88 is what you want. Basically any other major brand (Snap-on, Gearwrench 120xp, SK, Proto, Mac, Cornwell, HF, etc.) will be thicker. This is the ratchet. FWIW: If you're in a pinch (Matco/Armstrong gears backordered), GW 84 tooth gears fit in just fine. I bought a few sets as spares to eliminate warranty downtime.
If this is your only car, I'd hitch a ride to HF and get a cheaper one since it will work fine to do one job. :lol:
kossuth
Personally I'm a fan of my FHF80 Snap On. Can't beat it and I've really cranked on it. I understand your position on price though. I have a Gearwrench 120 in a 1/4 drive and it's OK.
bubinga
