Warped5
Greets to all ..
Picked this up last weekend and finally has a chance to fire it up today after getting high voltage out to the garage. The bad news is that (1) it has a very tiny leak where the feed tube meets the tank and (2) the pressure switch isn't working at all when 150PSI is reached.
The good news is that it pumps up nicely and the pop-off valve works as designed.
Let me preface the following by saying "In most cases, stock is just fine with me." I don't see a need to reinvent the wheel when I have no need to.
The problem is that I don't know the Sears model number. The label seems to have been exposed to some heat. With the model number, I can look up the part number for the switch and check availability ....
The specs as I know them are: 220V single phase motor ... 2 cylinders ... 20 gallon tank ... 150 PSI max ...
Anyone have any idea what the model number might be, or at the very least, who the manufacturer was?
TIA ..
TIA ..
