Need a door open sensor switch...
Teach
I am looking to power a light when the man door is open. I can imagine a sensor mounted to the door and the frame of the door that sends a signal to power an outlet/cord when the door is open, but turns it off when the door is closed.
Can anyone steer me toward the right product? Thanks in advance.
Steve W.
Southwest oHIo
You just need an indicator light, or are you looking for a bright light to illuminate the path?
Either way, a magnet on the door, with a reed switch on the frame will switch current to either a light or a relay for a bigger light. (Think "burglar alarm".)
Innovate1
I put a line voltage switch in the jamb by the hinges for a closet light. It was made for the purpose but it would not be easy to retrofit without opening up the wall. What Steve recommended would be fairly easy.
You could use a fan control center. It's a transformer and relay that mounts to a common electrical box. All the high voltage is enclosed and 24VAC is exposed.
https://www.grainger.com/product/2E852?gclid=CjwKCAjwwab7BRBAEiwAapqpTNdnxrVK1CfLdC8nskcxhK9LFZMW3luyZeSXAK6BYmphshxfT9NTTBoCMP8QAvD_BwE&cm_mmc=PPC:+Google+PLA&ef_id=CjwKCAjwwab7BRBAEiwAapqpTNdnxrVK1CfLdC8nskcxhK9LFZMW3luyZeSXAK6BYmphshxfT9NTTBoCMP8QAvD_BwE:G:s&s_kwcid=AL!2966!3!284662588489!!!g!477593405513!&gucid=N:N:pS:paid:GGL:CSM-2295:XU4CJF:20500731
jdm5
CT
Insteon (or many other smart home technologies) can do this - I’m just most familiar with Insteon.
Use one of these for the sensor:
https://www.smarthome.com/products/insteon-2843-222-wireless-open-close-sensor - surface mounted
https://www.smarthome.com/products/insteon-2845-222-hidden-door-sensor - drilled into jam - clean/hidden
Then one of these (you mentioned cord/outlet so going with those options):
https://www.smarthome.com/products/insteon-2663-222-on-off-outlet-white - replace the outlet if you want (cleanest)
https://www.smarthome.com/products/insteon-2635-222-on-off-module - plug in on/off module (a dimmable one is also available)
Smarthome has sales most holidays of 20-25%
908Jim
If you're a little techy this might be the perfect application for a smart bulb and a door sensor.
dcg9381
Austin, TX
As mentioned - with smart sensors and an outlet, this is pretty easy to do (completely wireless) - the senors I have, the battery lasts over 1.5 years... Some tech is involved in setting up "rules" that say "light on when door open".
66cj225
NH
Solution should consider if the signal ultimately winds up on the net.
The old way is a reed switch or magnetic switch set that will provide a hard contact.
Ultrasonic 'walk in, turn on' sensors have been around for sometime.
Photo IR sensors are another way.
Git
S Cal
If you really want to go low tech/cheap. Just buy one of these motion sensing bulbs
T
Teach
Thanks for the ideas everyone. I like the variety of strategies.
