Need a good 1/4" ratchet
M
mooman
CHICAGO, IL
Is that second one considered the RHFT Craftsman? I'd like to try one of those.
Just a little nervous about rebuilding it if it ever needs it.
mrholeshot
MEMBER EMERITUS
Mr.Nutcase
USA
I've only got (4) 1/4" ratchets. I just got the Plomb and have never used it. I much prefer the Fairmount, which was made in the 50's or early 60's, over either of the Cman ratchets. More comfortable, thin profile and nicer action.
Moonman the RHFT is the second one on chopper1..
It is a great ratchet, just little pain in the *** to take part, there is a snap ring under the bottom...... its almost the same as the SK's with the snap ring......
plinker
Northern Wi
Napa has the same ratchet, you could get a kit from them.
Rickster
SE PA
I buy and sell a lot of 1/4 dr ratchets so I'v had a chance to handle a lot of different brands. I would recommend three top 1/4 dr ratchets:
Snap-on hard handle roto head. This is a great all around 1/4 drive ratchet. Can't say enough about being able to rotate the handle straight and drive the socket like a screwdriver.
SK: small and oh so smooooth.
Craftsman RHFT: Been around forever, well balanced, works great.
If any of you guys are looking to pick up an extra ratchet, let me know. I have a bunch of different brands available.
filtered
Berks Co. PA
My vote is a used Armstrong 10-996 if you can find one. The head is the size of a penny. It's fine tooth and indexable. I bought mine off here for less than $30.
Robertob
Long Beach, CA
I like the locking of it... What's the street price on one of those?
Man I wish armstrong was easier to get locally without having to pay shipping. Same goes for Wright.
Robertob
Long Beach, CA
any love for the snap-on round headed 1/4 drive? I've never used one.
Or what about the Williams M-52A round head? Kinda plain looking but cheap and USA made.
lynam
CANADA
I have 2 macs i use daily
Here is pics of the type your looking for try ebay for a used one.
AustinRoepke
Not Chicago, Illinois
Here's Matco 88-tooth vs SK picture:
Digital caliper readings on head thickness:
Matco AFR58T: 9.3mm head, ~10.6mm with the lever
SK 40970:~13.3mm head, 15.6 with the lever
To be honest, I think the Matco's overpriced. It's by far the nicest 1/4 drive I've used, but it's not worth the $70 Matco wants for it (nor is any other 1/4 ratchet IMO). For a cheaper 1/4 drive, I'd go with an SK like the one in the picture.
M
mooman
CHICAGO, IL
Wow! Three pages of help from you guys.
Thanks alot. Keep 'em comming. Your giving me alot to think about.
Craftman RHFT is in the lead in my book.
KEH
I don't think you can go wrong with an SK. No one has mentioned Cornwell which I like fine. It's compact, but a real compact one that is easy to use is no longer made..the Thorsen with the exposed gears and the easy thumb lever direction change.
The Cornwell direction change system can be used with the thumb, but it takes a little getting used to.
KEH
MattT
What's the width of the Matco head? I'm wanting to try a fine tooth and Matco is top of the shortlist.
SO TM75 9.6mm thick x 22.0mm wide head. 11.4mm thickest on lever.
SO TM76 9.7mm thick x 21.3mm wide head. 11.2mm thickest on lever.
SO TM831 10.9mm thick x 22.7mm wide head. Lever fell off:wtf:
Mac MRR7 11.3mm thick x 24.6mm wide head. Round head.
BWright
Illinois
Love the length on that one! I could have used that when I did some work on the Civic earlier this year. How long is it?
That is actually a picture of the 1/2 inch model. The flex in 1/4" drive is not considerably longer than the standard. Only 3/4" or so. Look at the bottom two ratchets in this picture for reference.
M
mooman
CHICAGO, IL
I don't find it comfortable in my hand. Also, I keep hitting the direction lever while using it.
That's why I think a round head would work for me.
Davefr
OR
I'd go for the SK. I also hate small ratchets that have the lever.
1/4" ratchets need to be round head IMHO.
49 ford f-3
Boy, I sure give the MAC MR4C some love. You would have to Ebay it or have a student discount to get it for less than $30, but even at $52 it is a steal if clearance is an issue for you.
It is the smallest current production ratchet that I have found, but it does have a really short handle if you are one who really torques on stuff (I'm looking at you, auto mechanics). For my purposes it is awesome. Our aviation maintenance shop (7 guys) have 6 of them between us.
I reviewed a bunch of 1/4" ratchets on my blog
This is the only way that I have been able to make a thinner ratchet:
It is a Craftsman driver with a ground down adaptor.
Even this setup is barely skinnier than the MAC.
cole_CT
Connecticut
Almost certain that you can buy a GearWrench 120xp 1/4 drive ratchet for far less than $30 on Trident with Mike's current sale
jeepman1
se iowa
I have it and use it everyday... I do hvacr and find myself using it at the angle setting or as a ratcheting screwdriver... I like it a lot. I've only had it for 9 months but so far I've not had any issues.
Sent from my XT1055 using Tapatalk
ac427
Hi Jeepman, At the angle setting ?
I think you have the Zyklop 1/4" (which also caught my eye because of the Chro Moly construction) rather than the Zyklop Mini
The Zyklop Mini is for confined spaces
jeepman1
se iowa
Yes I do[emoji1] [emoji1] for whatever reason your pic didn't load when I looked at this thread originally.... My fault !
tt350z
Minot, ND
I got a chance to play with the zyklop mini when the WERA rep brought some.
I really liked it. The thumbwheel is nice, especially when in a confined space and theres not enough backdrag to make it ratchet. Just spin it down with your thumb instead of trying to get squeeze in your other hand to run the fastener down.
I probably dont need one for my personal home use, but for my work (Aviation) that would come in handy quite a bit.
Kensgarage
My OLD Challenger by Proto is the smoothest and lightest back drag on the planet.
This is a close second and the QR makes it great.
http://www.ebay.com/itm/PROTO-J4749...229574?hash=item4d23455ac6:g:O4gAAOSw42JWDpvM
All my Wright socketry is 3/8" but I have the 3/8 in the 1/4 body as well (3430-3440). Due to using them I'd buy this(and might anyway :thumbup: ) in a heartbeat too.
http://www.royalsupply.com/store/pc...-45-Teeth-High-Strength-Rachet-2689p50227.htm
I'll be damned. Grab this
http://www.ebay.com/itm/Proto-Chall...817650?hash=item4af26d1f72:g:4MYAAOSwZd1VZiak
Kensgarage
