Need a good nitrogen regulator
Grant Gunderson
Bellingham, WA
I need a new nitrogen regulator. The Chineseium one I’ve been using from Amazon is really hard to adjust when changing working pressure. My typical working pressure is between 100-500 psi as I use it for charging shocks.
willf650
My only experience is with a Uniweld nitrogen regulator as that’s what the supply house sells. I had two over the course of 30 years but use them for HVAC work. I don’t believe they go to 500# though if that’s what you truly need. I generally only take them to 250#.
Chipm
Georgia
Pretty sure mine is Smith. It goes to 150 or so but they have different ranges. I pull it down to 90 for running air tools.
L.Cheapo
We have a couple at work that are at least 5 years old. Our mechanic uses them all the time in the 150-250psi range. I'll try to remember to check them out next time I'm at work on Tuesday if you can wait that long.
rlitman
Long Island
...I use it for charging shocks.
Most people using inert gas regulators don't care too much about pressure stability, and in that case Chinesium is just fine. I've been using Chinese argon regulators on my TIG welder after my Victor failed, because the rebuild was more than a replacement (and current production Victor is Chinesium anyway).
But I'm sticking with good regulators for my OA torch (I use old Harris two stages), and your use case is the same. Cheap regulators can be touchy with how the knob turns and presses on the diaphragm, so dialing into a specific pressure is much easier when they use tight fitting low friction components in the right places (since regulators don't get lubricated). Smith has a great reputation in the welding community, but there's lots of good stuff made in the USA and EU.
L.Cheapo
My phone reminder came through today. Our mechanic likes our Harris 8700 series. It's at least 5 years old, probably much more. Gets used multiple times per week. No issues.
G
Grant Gunderson
Bellingham, WA
Ended up going with the Victor as the enclosed gauges seemed more robust. It’s a million times easier to adjust pressure than the Amazon Chineseium one I had before. Can’t dial in pressure bellow 200psi, but I have two valves and a bleed off on the fill manifold to do that.
Beerhippie
Far NE Oregon
The enclosed gauges look much more difficult to replace when they go out of whack--which all gauges eventually do.
Bigblue&Goldie
Got a link? I just tossed my old shock fill setup.
pcmeiners
Was curious so I Googled..... 2 stage nitrogen purging regulator 0-500 psi....., a 2 stage regulators produces even pressure all the way down, no need to re-adjust as the tank lowers in pressure. Seems like your stuck with a single stage unless you have big bucks. Matheson makes a number of 2 stage high output regulators at a high prices, you might get lucky on Ebay.
G
Grant Gunderson
Bellingham, WA
That’s a good point. We will see how long these hold up for. I just need the regulator to get within ball park, then I fine tune it with a digital gauge on the fill manifold.
Nitrogen regulator my manifold is pretty old, if I was to buy a new one it would be one of these and then upgrade the gauge to digital.
These guys are the best. Great customer service and they can build whatever you like. The only thing that would have to be changed from a normal Harris regulator to get to 500# would be the spring and the gauge and they can easily handle that.
That’s an awesome resource. Thanks for posting it.
