Hi guys, I would appreciate whatever help you can offer
I've got a new detached garage built, and to make a long story short, the 100 amp panel won't provide enough power to run the welder and the electric in-floor heating at the same time (each needing a 50 amp breaker).
My plan is to have a 240V 50 amp breaker that feeds a DPDT relay. On the NC side it would provide power to the heater. On the NO side it would provide power to the welder.
A manual transfer switch would do the trick (basically a sub-panel with a cage on 2 breakers so they can't be energized at the same time), but I would prefer something that can be hooked to a timer, so that I can switch it to the welder and then it will revert to the heater after a predetermined amount of time (in case I forget to switch it back)
This would be the ideal sort of timer - http://www.ebay.com/itm/190714665916?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
As regards to the relay, I feel like one of these might do the trick, but I am unsure - http://www.ebay.com/itm/NEW-50A-220...165?pt=LH_DefaultDomain_0&hash=item3f3a0245fd
They can be found with a 120v coil, but I don't know if it would handle the load of the welder (which is what, resistive?)
One of the variations of this looks like it would work too, but I don't know
http://www.gordonelectricsupply.com...h~product~part~5589317~ds~dept~process~search
What do the experts/DIYers say?
Thanks!
Thanks!
