Need a new air hose
58Yeoman
Central IL
I was working in the shop today and hear air escaping when I was using my tire inflator. Thought the fitting was loose, but then noticed the cracks in the hose...for at least 4' before they got smaller. Time for a new 50' hose to put on my wall unit. Looked at HF, Menards and Farm & Fleet. A lot of different kinds, some hybrid. I'm thinking pvc is usually very flexible (I have 25' pvc jumper cables), but what has everyone found that works well for them? I'm looking at 3/8" x 50'. I still use some air tools such as 1/2" impact when needed, smaller air tools and mostly air guns and filling tires.
rlitman
Long Island
58Yeoman
Central IL
PVC air hose is the type that gets rigid and brittle in the winter. This is my most recent purchase, and I'm very happy with it.
It's a smaller OD than the red rubber hose it replaced and more flexible, so it spring returns onto my Reelcraft much more easily.
That's odd, as the jumper cables I have are very flexible in any weather, and the one you show on Amazon is pvc, rubber and nylon. I'll check on the Flexilla hose. Thanks for the replies.
kaymccampbell
Upstate New York
If you don't want to shell out, then the HF Fakezilla hybrid hoses are pretty nice. I've got a couple. When my slowly hardening PVC hoses STB I'll be getting new hybrids to replace them.
kaymccampbell
Upstate New York
Make a liar out of me. Flexzilla is only $10 more than HF for a 50' length. So, if you're getting a few lengths, it's not that much more expensive. There used to be a significant difference.
bdbecker
Iowa
Another vote for Flexzilla. I have both a knock-off (Husky from HD?) and a real one. There is a noticeable difference between the two even though they are supposed to be the same.
CraigStu
Blacksburg, Va
dzahm
NC
I wasn't as happy with flexilla- but I absolutely love my goodyear -its prob 25 yrs old and still soft, pliable, and rolls up nicely- I don't use a reel so when I roll the flexilla is seems to be slightly more finicky. (like a memory sort of- you have to kinda roll it around to make a nice roll up) If I used a reel with the flexilla; it would probably be ok- But I will probably spend the money for goodyear because of how long it lasts
tstaude
SE Wisconsin
Flexzilla over here, have two 50' and one 25' for the shop.
Absolutely love them.
They go on sale around Black Friday too
tester19
chigago
Really liked the old Harbor Freight Diablo hose. It's now been replaced by the Merlin version which looks about the same. Very nice with a small diameter and end protectors.
Merlin Air Hose
rlitman
Long Island
Straight PVC is what gets really stiff in the winter, but PVC is often alloyed with other elastomers (like rubber, which also can stiffen in the cold, but not to the point of becoming brittle) that improve it's flexibility in the cold. This applies to extension cords, jumper cables and hoses equally, and unfortunately, unless the manufacturer makes cold weather claims, you can usually just assume they're using the cheapest (stiffest) materials.
Flexzilla makes good stuff, but so do lots of other companies. Be aware of the difference between a hybrid hose and a polyurethane hose. 1/4" polyurethane hoses have their place, but too many of mine have gone brittle and fell apart after 10 years or so. Time will tell how good the hybrid replacements are.
I chose the Amflo hose I linked specifically because the thinner outer diameter allowed me to pack more 3/8" hose onto my reel. The rubber hose it replaced was a bit too chunky and I routinely had issues getting it to retract all the way.
quilty
I'm using a 1/4" Flexzilla now and like dzahm mentioned, it does have a bit of a "memory" to it so it can be challenging to roll up nicely when you're done with it. I'm thinking about upgrading to a Reelcraft unit. I like the idea of the reel so I don't have to unwrap and wrap up a hose every time I want to use the compressor.
58Yeoman
Central IL
Flexilla for the win. Bought it at Menard's for around $35. The original hose lasted for quite a few years, so this should last at least as long. Thanks for all the replies.
