Need a solution for temporary tools on work bench
skipnay
PA
Need a solution for temporary tools on work bench!!! Pictures added
I need help making some stuff more easily to be used on the bench but not on the work bench all the time. I bought 2.5" square tubing like what a truck hitch is made of. I also bought 2" square tubing to go in like a receiver. My problem lies in trying to weld the 2.5" square tubing to my bench. I have a 40"x12' work bench. I ran 2"x3" square tubing the length of the 12'. I have 2"x2" box tubing for cross bars. The 7/16 steel plate for the top sticks out about 4" in the front.
My problem is, what is the best way to weld the 2.5" x 2.5" to my work bench? Do I weld it to the 2'' x 2'' box tubing and cut 2.5" out of the 3''? My other choice was to weld the 2.5" to the bottom of the 2" x 3" box tubing. Lining the one side 2.5" x 2.5'' to the side of the 2" x 2" cross piece and then weld a couple 1/4", or 3/8" flat steel to the sides of each. The other side will have the same flat steel only be welded to the side of the 2" x 2" and to the top of the 2.5" x 2.5".
What idea's do you have? If it matters I will be using it for a woodward fab hand shear, eastwood bead roller, a vice, tubing notcher, and so on. I don't want these on the bench at all times. I already have one vise on the bench on one end.
2oolhound
BC Canada
One problem with the receiver hitch system is a lot of tools, vises included are designed to be mounted on top of a bench. With a receiver system they are mounted in front and below the surface. With many tools and the vise is a classic example the slide will hit the top of the bench unless it has a rotating base that is really high or you build a riser into the mount so the slide will go above the top of the bench.
In hind sight your 2" X 2" cross bars should have been your 2 1/2" female receivers and been cut through the 2" X 3" runners so they opened right under the 7/16th top plate pretty much. One of the beauties of working with steel is you can cut slots through the 2" X 3" tubing with a zip disc and weld in the receivers where you want them. :sad:
You should round up most of the things you'd like to set up on the receiver system and just hold them up to the front of the bench to get a feel for how it will work if you just weld the 2 1/2" below the existing frame work, it might be fine but I like them to be close to the top of the bench surface. You can put them up high at the ends of the bench at least.
skipnay
PA
I actually have thought about doing one in the front and the other on the side. Especially since the back and the other side is up against a wall. I don't ever think I will be needing all 12' of my bench. I liked the idea of actually having the 2.5"x2.5" down further on one because the hand shear, bead roller, and the vise I could use the actual table to help hold the piece of material I'm working with just incase I don't have an extra hand. I run into that problem now with the one vise. I'm constantly looking for a piece of wood to prop the other end up.:dunno:
2oolhound
BC Canada
Yeah, I really like the receiver hitch concept. I have one low one on my lathe frame where I keep a small grinder for sharpening bits (of coarse I get to sit down when doing that). I have about 10 or 12 receivers located throughout the shop on work benches, motorcycle lift, lathe stand and a wheeled pedestal made from a truck axel housing.
You may have gotten more response in the fabrication and techniques section. A lot of guys have adjustable height benches too.
