Need a source for foam rubber gasket material
Steve in Mi
Mid Michigan
Where to buy foam rubber gasket material. The self stick (adheasive on one side) foam sponge stuff sold by the roll. I need some 1" wide by 3/8", 1/2" and 3/4" thickness.
I have a sand blast cabinet I'm cleaning up for fresh paint and really want to replace all the gasket material on doors, light and window. I carefully removed the original foam gasket material and maybe could apply a two sided adheasive tape and save some of it but if the cost isn't out of reach, I prefer fresh gaskets to seal up the blast box. Thanks for any leads.
buening
Decatur, IL
Sounds like weatherstripping that can be found at your local Lowe's or Menards in the door hardware section. It is available in varying thickness and widths. I believe Wal-Mart carries it too.
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
Keep looking, I have seen very high density material around. I am sure McMaster has what you need for door gaskets because I have purchased it from them before. You can also try industrial rubber supply houses found in most larger cities.
