Need a water tight enclosure
Overlord66
Montana
I'm working on a project to monitor our sump pits and water pumps. I have an area under our deck that I'm going to use as the junction for the sensors.
I need a water tight enclosure with a single duplex outlet in it. I know they exist but I can't seem to find exactly what I'm looking for. It doesn't need to be any bigger than 8"x12" and a few inches thick.
Any ideas on what to look for?
the gypsy
Montreal, Quebec, Canada
I was going to suggest Stanley waterproof box but I don't know what is the smallest.
You might want to try an electrical wholesaler, they must have watertight boxes for exterior electrical boxes.
MoonRise
ummm, a metal or plastic outdoor watertight electrical junction box/enclosure?? :D
Carlon 12x12x6 indoor/outdoor plastic junction box, Model # E989R-UPC, Store SKU # 693878 at HomeDepot. about $35 (next smaller listed size is smaller than what you said you wanted/needed.)
Dustball
Hudson, WI
Is this what you're looking for?
MixManSC
South Carolina
Not sure about one with a duplex outlet (you could always cut the plugs and hardwire) but one commonly available are junction boxes for pool lights. Often they are installed in the base under the diving board but they don't have to be. They are heavy cast brass and truly do not leak if installed right.
