cmandp
Now that I have a bench grinder I need some fresh wheels. Basically I want two wheels one for my random grinding needs and one for sharpening drill bits, wood chisels and other delicate tools. One problem is I need 7" X 1" (width) wheels which aren't the most common size...
For general stuff I figure something like one of these two wheels:
http://www.drillspot.com/products/60607/Norton_66252942292_Bench_Pedestal_Grinding_Wheel
or
http://www.reidsupply.com/sku/RAD-A090611/
For sharpening what should I look for? I figure a fine wheel like 100 grit. I also read that softer wheels are better because the wheel doesn't clog as quickly and reduces the heat generated. Should I worry about this or will any fine wheel work satisfactorily?
Also could anyone suggest sources for wheels other than the usual industrial supply places like MSC, Mcmaster, Grainger?
I would appreciate any guidance/ wisdom/ comments.
or
