ProTex
My current die grinder is a Craftsman 1/4" pneumatic. I realize some of you might suggest I upgrade my die grinder before I buy accessories.
So be it.
Here is what I need to do. I need to remove a steering stem from a vintage Honda motorcycle and replace it with a newer Kawasaki stem. The s.o.p is to grind down the weld on the bottom of the stem and press it out; do the same to the donor stem and press it into the Honda clamp.
The stem and the clamps are made of steel. I need to buy some (I assume carbide bits) to grind away the welds so that I can press the stem out from each triple clamp.
I spent a couple hours this afternoon "grinding" away with the set of stones that came with my die grinder.
There has to be a better way.
My question to you guys is can you suggest a type or source of the grinding bit(s) I need? I realize they will not be inexpensive, so no Harbor Freight/Northern Tool ****, please.
I'll attempt to post some pics of what I'm talking about. Perhaps pics can better explain than my typing.
Here is an unmolested steering stem:
Here is the area that needs grounded and pressed:
Here is what I accomplished this afternoon using the grinding stones that came with my d-g:
Obviously photography is NOT my strong suit.
Thanks for your replies/suggestions.
Jim
So be it.
Jim
