Need advice for how to approach a ceiling in my garage shop I have a late 50's detached 25' x 25' oversized 2 car garage that is mostly being used as a woodworking shop with the stipulation that my wife can park on the other side in the winter when it snows here in MN. Being that I'm in MN I'd really like to get this space insulated and occasionally heated.
Once I have the wiring fully sorted out with more outlets than I think I'll need I plan to put r15 craft faced fiberglass batts in the walls and put the OSB back over it. That part seems straight forward.
The piece I'm less sure about is the ceiling. The garage has a hip roof all the way around and has 5 2x6's (joists/rafter ties?) spanning the full width of the garage about 4' on center. They are each fastened to the rafters above in a couple of places.
I'd like to end up with an OSB ceiling with about r40 worth of insulation on top of it. Seems like blowing in about a foot of cellulose is a good approach to the insulation but I could be talked into more fiberglass batts/rolls.
My question is this. How much additional structure is required to support the osb and the insulation? This wont be used for storage. The related question is how thick of osb is appropriate?
4 approaches I've considered.
Are any of these preferred over the other structurally speaking? I'd really prefer to avoid any posts. This would be mostly a diy effort on my part with some occasional help.
- Run 2x4's on the flat perpendicular and nailed to the underside of the existing joists. Thinking about 24" on center covered by 1/2" osb. Drawback is losing 2" of ceiling height. Pro is much quicker than option number 2.
- Add 4' 2x6's perpendicular to the existing joists so that the new lumber fits between the joists. The bottom of the new 2x6's are in the same plane as the bottom of the existing joists. Either 16 or 24 on center.
- Either of the above options but reducing the amount of lumber and increasing the thickness of the osb.
- Add more joists with blocking parallel to the original joists to reduce the spacing between to 24" instead of 48". Guessing my odds of getting a board that long in place with the roof still on are pretty slim so I'd need to join shorter lengths.
