Need advice on a new Vise
Flared Base
CA
I have the Capri vise. I picked it because of the aforementioned forged steel construction making it have a smaller form for the same given jaw size which I assume should make it more versatile. I do not know what alloy the screw is made of, but it looks to be a nicely machined acme thread. There is no slop in between the treads and the nut when tightening or loosening the vise.
In this photo, any irregularity on the threads is grease. I guess one criticism I have is they could have finished painting it before shipping it off to me. I don't think I am as hard on vises as some on here (never used a cheater on it), but it has easily done everything I need it to do. I do recommend this vise. I think Yost has a very similar one as well. Both are 'influenced' by the Ridgid forged vises with the biggest differentiation being the Yost and Capri have removeable jaws.
PierceA
An experience I had with an imported vise:
A business was closing, and had a sale of remaining tools, benches, shelves etc.
On one work bench was a Starrett vise, about 3.5" or 4" jaws. It was cast in the typical Starrett style.
It was an enclosed-screw vise, and looked used, but not broken. The handle turned, and the dynamic jaw moved in and out.
I did not do an extensive look-over on the vise, nor did I run the jaw all the way in or out... I just spun the handle a few revolutions and pushed and pulled on the dynamic jaw. There was some in and out free-play but nothing terrible.
When I got the vise home, and proceeded to clean it up and attempt to tighten up the excess endplay in the nut and mainscrew, I found that it not only was an imported vise, named with an American company's name but NOT made with quality materials.
The nut was very loose in the dovetail in the bottom of the static jaw, I tried to shim it and take up the free-play, but when I did, the mainscrew would bind in the threads and jam !! As I watched the mainscrew thread into and out of the nut, it was painfully apparent that the mainscrew was stretched, and had a slight bend in it, Straightening the slight bend made the binding in the threads worse.
In the end, I gave the vise to a guy who needed a vise of any sort for fairly light work, I showed him how the threads jammed and he just shrugged and said, I can live with that..
Currently several American vise retailers, like Wilton, Yost, and Reed, have many imported products in their available for sale inventory, with their names either cast into the vise or a stick-on label showing their name..
To me it's a shameful end to a once thriving American industry. But there is not that much hand work done in industry these days, and therefore a high quality machine vise is a feature of past industry practices.
The above mentioned vise retailers, do still make their largest vises in the USA, at least from what I have learned. Wilton still offers their larger Bullet vises that are made in America, and Yost still offers their largest Combination vises that are made stateside. But Reed's website only shows 'homeowner' or light utility vises that are not remotely close to their products made as late as the 1980's.
I have several Reed 4", 4.5", 5" and 6" vises made after 1950, and they dwarf the current vises Reed offers with the same jaw size.. It's a shame.. I think there is still a market for a good, high quality vise. BUT that is from MY point of view.
I grew up struggling with a cheap, open-screw vise that didn't tighten up square, the swivel base would constantly work loose, and it was very frustrating for an 8 year old kid trying to make things out of scrap steel and wood..
When I started working in a car repair business while still in High School, I learned how nice a good heavily built vise is.. The shop had a big vise that I simply never looked at closely, It had an enclosed screw, and yes I did occasionally use the top of the dynamic slide to hammer on something bent to straighten it. I'm guessing the vise was a 4" to maybe a 5" vise, It opened wide enough for me to use it to hold cylinder heads in while I drove out valve guides, cut new valve seats and lapped-in valves for engine rebuilds. I wish I had a clue what make the vise was. Too many years and since the vise simply worked well at the jobs I needed it to do, I just ignored it, and used it. I did occasionally wipe grinding dust off of it and squirt some motor oil on it, and up underneath at the mainscrew.. LOL. I now know how much better the vise would have worked had I given it a bit more cleaning and lubrication.
When I set up my own shop, my grandfather gave me what then was to me a HUGE vise.. I still have it, it's a Reed 404-1/2 R. A swivel base, swivel jaw, very heavy vise. I never used the swivel jaw and until a few years ago, didn't know that the pin could be removed.. it had been hammered on and was almost flush with the top of the backside of the jaw.. After getting interested in a big vise that I had bought, I started reading about various makers and soon went to look at my long-time user vise.. and found it to be a pretty high quality and collectible vise.
Anyway, Keep looking, there will be hundreds of good quality American made vises within 100 miles of Youngstown.
If you want to take a road trip, I'm roughly 275 miles from you, but have several good heavy user vises that I would part with for $100-$150 each. 4" or 4.5" either fixed base or swivel base. These would be dupicates of various commonly available vises that I have in my collection of American vises.
The photos are of the 4 vises I found within an hour's drive of my home on one evening at two or three different garage or estate sales.
Hope this helps..
PierceA
drivesitfar
Pierce: very well written post. I didn’t know Starrett had any of their vises imported so maybe before they stopped making vises altogether they tried the cheap imports and their quality and vise business failed?
In any case it looks like you’ve been buying up as many old good vises as you can and your collection and skills are amazing.
MarkH
Kansas
A vote for the used vise if you can find it unless you have enough of a business use to get a new made in USA, Japan or Europe one. When we need an additional one we usually get them from auction sales. We do not restore them. We clean and lube them and they go on the bench. How long do we expect them to stay in use? The ones my grandfather bought are still on the benches at one of the shops. Two large Morgans. Like our other tools they do receive abuse to keep the machinery moving. We have placed parts in them and swung at them in the vise with 12 to 16 lb sledges even with heat and lubricating fluids to loosen the offending parts. I am guessing those two vises are close to 100 years old now. They keep working. A machine off the line costs us enough we do what we have to, to get it back to work. So if a tool gets some abuse it is much less then the cost of the machine off line.
I have bought one Chinese vise and it has shaped my opinion of made in china for years. I had another shop to supply and went to Fleet and bought a very large new vise. Bigger than any we already had. Took it home and put it on the bench, it looked great. A couple days later I had one of those items that did not want to come apart. So I placed it in the vise lubed and heated it and took a swing with a fairly small hammer. First swing OK, 2nd swing kinda a funny noise, 3rd swing vise laying in 3 pieces on the floor. Looked at the box and it said made in China. Thought never again. Dropped the part off at the blacksmith and got it fixed at a cost.
Ran into another large Morgan at an auction the next weekend. It is still sitting on the bench decades later. It may not be as fine as many people's restored vises but earns its keep. It is a vise not a precision instrument so as long as it holds as it should no issues. Clean and lube them and they seem to keep working.
drivesitfar
Renegade: Those new old stock vises look pretty decent for $125. How much is shipping? My guess is they are or similar to Jet brand vises made in Japan and I’ve always thought they were pretty decent quality.
Renegade1LI
long island ny
From Kansas city to LI NY 70$, that could be a deal breaker depending on where you are. I have an old craftsman floor jack late 70s, made in Japan & still using it today.
exmaxima1
Midwest
I inherited my dad's Sears "Made-in-Japan" floor jack dated mid-70's. I recall it was made by Norco. I called them a few years ago to find out what replacement oil to use. The customer service guys started laughing in the background about me having another one of those indestructible jacks. Their advise was to leave the oil alone and just use it as is. Recently I gave it to a friend, but it is still working today.
M635_Guy
NC
I just bought a $200 Yost 5" 750DI 60lbs Vise, I seem to think its made in Taiwan, that seems like a nice build for the $.
https://www.amazon.com/dp/B00CBL62HQ/?tag=atomicindus08-20.
Its 60k psi ductile iron and steel, with a 3yr warranty.
It's MiC, but I have one and have to say I've been extremely pleased with it. It doesn't live a hard life, but I looked pretty closely at it when I unboxed it and it looks to be well-executed. I really wanted the rotating function, replaceable faces and pipe jaws, ductile iron or better etc, and it was very well-reviewed everywhere I looked.
Capri does make a 5" MiT model that's about $80 more ($280) than the Yost 750-Di with similar specs, but has a 10-year warranty and looks to beefier. There's also a 6" for twenty bucks more.
Busted_Knuckles
Northwest Illinois
It's MiC, but I have one and have to say I've been extremely please with it. It doesn't live a hard life, but I looked pretty closely at it when I unboxed it and it looks to be well-executed. I really wanted the rotating function, replaceable faces and pipe jaws, ductile iron or better etc, and it was very well-reviewed everywhere I looked.
Mine is used to hold mostly mainshafts and cluster gears when Im doing transmission work. So I use it as a clamp, and not beating on anything. I bought it for the rotate and the pipe clamp as well. Also bought two sets of soft jaws for delicate work.
Ive got a fleet of larger wilton vises to beat on.. ( that dont rotate or have a pipe clamp ).
I saw the Capri competive model as well, but not sure why I didnt go that way. It was not about $.
M635_Guy
NC
I've gotten a lot of use out of the rotating feature, and very glad I have it. If I ever add a second one, it will likely be a vintage MiUSA standard-style vise.
I just dont know enough, BUT I found a dealer an hour from me he has an ad on FB with over 70 antique vises and an anvil in stock. He is in Bolivar Ohio
Is that Zach? He seems to have a reasonable stock.
I would Stay away from the fully restored ones (painted etc), as there could be repairs or breaks hidden. (Not questioning him, just painting). Lotsa guys in Ohio selling vises, you just gotta find their source, and not pay their markup. garage and estate sales around here, auctions elsewhere I hear.
mlyonsdc
USA
Thanks everyone. The Yost checked a lot of boxes for me, I am getting ready to do a 25.5 cage install on my Buick GN which is at least 100' of CM tubing so the swivel pipe vise is probably going to come in pretty handy.
I am going to keep my eyes open for an old vise and would like to have one. I may even buy a nice Wilton Bullet some day.
jsulli
You do NOT have to "restore" an old vise like others have already stated. I did to the Prentiss because it's over 100 years old and I felt the previous coach makers urging me to. The 100 year old Reed 31 I've had for a few years was merely cleaned up and lubed, still wearing the patina/gouges from it's history.
I'd also sooner buy an old vise that doesn't have a new coat of paint on it because paint can hide serious flaws like cracks or broken and brazed together parts. You don't want something that's been broken and brazed/welded back together unless you get it for fire sale prices and still not expected to be used for heavy duty work. Northeast Ohio should have a heck of a lot of vises from the industrial/agricultural base that used to be there.
Good point on the repaints having flaws, I'm presently looking for a vise and have seen repaints which look nice and now will keep your point in mind.
RoninB4
Under My House
Good point on the repaints hiking flaws, I'm presently looking for a vise and have seen repaints which look nice and now will keep your point in mind.
-If it's an old vise I expect it have less visual appeal as it wears it's history on the outside. Casting techniques back then didn't produce slick appearances and casting molds degraded over time. If you find an old(er) vise that looks like a beauty queen it's likely been given the "beauty treatment" and that might be hiding flaws, cracks, or welds. An old(er) vise that's a bit rough looking at least has an honesty about where it's been and how it is now. In the world of metal working machinery a repaint is called a "rattle can rebuild" and is always suspect. I wish you good luck in hunting, when you find one in good working condition the search will be worth the time spent looking. It was for me anyway.
autopts
I have an older 6" Craftsman vise that is long overdue for the scrap pile. It has a ton of slop wont clamp anything tight and is just not a good vise. I was at HF the other day playing with the Doyle 6" vise and thinking how much nicer it is than the ****** Craftsman I have is. It wasnt "cheap" at $200 not exactly Wilton machinist price either.
SO what say GJ vise experts for a new vise that works well and does not cost a fortune?
I also was inpressed that that HF 6" Doyle actually 6 1/2" with 60,000 PSI tensile stength and 9900 clamping force and it takes 1765 jaws also. Comes in at 70 lbs./ It could be made in Taiwan. Sign up and get it for $179. It's a good bang for the buck.
jsulli
here's an older vise that pivots 360 from flat jaws to pipe jaws. its heavy but doesn't weigh a ton. problem is there are no marks to identify who made it. looks like original paint and smooth operation. one thing noted is the 360 swivel locks when you secure a piece in it, and the flat jaws do not close completely. the seems to have been a square riveted label on it which was removed. nice clean vise at estate sale and after talking to seller got down from 80 to 50 dollars. anyone have any idea who made this by chance. also there is nothing on vise like a pin or bolt to lock, only when you tighten up does it lock 360 swivel.
ecotec
Chinese wonder vise… people who have them love them. It is an amazing form factor. There are American versions, but they are marked as such.
You need to mount them RIGHT at the corner of your workbench… so when you turn the jaws sideways the jaws are beyond the edge of the workbench.
Mgdoug3
KY
Most likely Chinese but one of the better Chinese ones. It'll be a good daily user. I have a 5" Dewalt and a 6" that needs some cleaning. I plan on building a welding table and mounting them. I would rather weld and use a grinder on them than my nicer vises.
