thool
First of all, the last type of welding I did was stick back in junior high over 30 years ago.
I have a bunch of old dock stands made from steel tubing. The height of the horizontal is adjusted by bolts running through nuts welded on each end. (Imagine a huge H where the horizontal piece slides up and down.) Unfortunately, a lot of the bolts have busted off, making adjustment impossible. Rather than send them off to be repaired, I'd like to cut off the old nuts and weld in new ones myself.
I'd like to get something that is portable enough for me to load into a truck. It needs to run off 110V AC. I'd rather not have to use any kind of gas, so I'm thinking stick. Material will be steel, up to maybe 12 gauge. Does HF have anything entry-level that would be good for tinkering with? I'd have to get a helmet, gloves, clamps, some sort of apron as well.
Thanks.
Thanks.
