Hi,
I am planning to install an outdoor 50 amps plug in my backyard for RV. Following is my plan, and I would like to get an advice on any issue it may have.
The main wire panel is in the basement at front of the house, I am planning to install the plug on a post 30 feet from the back of the house. I will install a 50 amps GFCI breaker, running #6 UF-B wire from the panel to the back of the house (about 50 ft). Drill 1 inch hole for the wire to get out to the back of the house.
From the back of the house, install a junction box (about 3 feet above ground outside the house), it will connect IMC conduit downward, going 6 inches underground. There is one 90 degrees turns for the conduit; plus two 90 degrees turn for enter / exit the ground level. The 50 amps plug is a 14-50R receptacle inside outdoor enclosure mounted on 4x4 post 3 feet above ground.
I have couple questions - the total wiring length is 80 ft, 50 ft indoor, 30 ft outdoor inside conduit.
- does a 3/4 inch conduit works ? can I fish #6 wire through 30 ft conduit with 3 turns ?
- is it better to have run 30 ft wire outdoor, and 50 ft wire indoor and connect it at junction box or just a single 80 ft wire from panel to plus ?
Thanks for any advice.
