oscarsnapkin
- Joined
- Feb 22, 2025
- Messages
- 573
This is a door next to my steps that provides access to a small, side attic. It had a piece of paneling on it, which I was in the process of replacing. When I removed the old panel it revealed that the door had split on the hinge side, and the hinge screws started to pull out of the door. I am going to cut a new piece of plywood to use for the door, but I am unsure how to make sure that I attach the hinges properly so the door is not lopsided. I don’t know if I should remove the hinges from the door frame and bench-mount them to the door? What’s the best way to make sure the gaps are even between the door and frame? Any help would be appreciated. Thanks, as always!
