need advice on new shop plans
bdog
I am closing on a house with 7 acres in a couple weeks. It has a double garage for parking the cars a 30 x 40 dirt floor steel building, and a 40 x 50 concrete floor steel building.
I have my own business and need to store 5 pickups, 7 trailers, 4 atvs / utvs, and other misc small equipment.
I am planning on using the existing buildings for parking, and building a new insulated shop to work on things in and probably store a few of the vehicles / trailers so they are not so crowded.
I am thinking around 3000 SQ ft but am not really sure how I want to layout the shop as far as dimensions, number and size of doors, etc. my first thought was a 50 x 60 building with three 18' doors on the 60' side. Any ideas or thinks to consider will be greatly appreciated.
wayne 70
If i were to build a new building again there will be 2 bay's that have door's on each side to drive thru for trailer's.
s_morrison57
Vancouver BC
Planning a new garage is so cool. Things to consider are the drive through option, doesn't have to be on every bay but it is a nice thing, power, water, washroom, lights and heat are all considerations. Ceiling hieght and a hoist should be thought of now, you don't have to put this in but if you can think it in the plan it can add up to a lot less grief later. Up stair storage/office space??? Cable TV, phone line(s) the net. Windows, flooring, if you put it in, AC ?? Man your a lucky guy!
ddawg16
S. California
X2 on the drive through....
Think in terms of a central work area....bays on both sides...
Also...consider a second story....put a hang out room up there....storage..etc. The cost of the second floor is a fraction of the ground floor.
But we must warn you....pictures of the project are now manditory....failure to do so can result in a lot of harassment....
medic583
Northwestern Ontario
Hmm... how about...
  • Line a room with metal on walls/ceiling for easy clean up
  • Separate rooms for separate work spaces (mentioned above I think). Keeps sound/noise down, don't have to heat/cool wasted space not being used.
  • Thick walls (2x6 or 2x8) for insulation to keep building warmer in the winter, cooler in the summer... don't skimp on 2x4 walls :)
  • Good quality insulated doors (big doors are nice... but even the best insulated ones do not keep things warm like a wall full of insulation does... same with cooling in the summer).
  • 10' plus ceilings or cathedral trusses - ceiling fans to circulate heat/cool.
  • Room-in-Attic trusses or a loft over an area where you will store the smaller vehicles
  • Plumb air lines in for the compressor
  • Separate room for air compressor/vacuum system
  • Separate room for painting or somewhere you can put vents/fans in walls.
  • Radiant in floor heating when the slab is poured (no open flame in the room)
  • Office to keep dust/dirt out of the computers used for invoicing/browsing the net for plans or manuals, etc...
  • Scissor style trusses for lift if cannot go higher on the walls.
  • Air conditioning in shop for hot/humid days
  • Lots of opening windows/skylights for summer/winter light and venting - placed so building can take advantage of natural heat/light.
  • If steep roof slope, maybe build seperate entrance on gable ends so snow coming off roof doesn't land on people when entering/leaving :)
  • Lots of 220V plug ins where you might eventually want to put and air compressor, saws, welder, etc...
  • Plugs on the ceiling..
  • Pull down ladder into the attic for more storage space.
  • Beam in attic before gable walls go on for lift points for come-along (to spread weight over several joists)
  • Garage Screen door kits for keeping the mosquitoes out at night when you want to open the doors for cooling.
  • Lean-too/porch on the back of the shop to store trailers, etc... that do not need to be inside just out of the snow/sun.
  • Conduit run in through the slab before the pour for things already mentioned... cable, Ethernet, alarms, etc... give yourself enough room to pull more wires later
