Need advice on outdoor PID lighting
vintovka
Going to be adding 4 outdoor PID floods soon. Tired of being stuck with garbage and looking for advice on getting some good ones. Lights will be on dedicated circuit, One switch. Four lights one on each side of the 24x30 garage mounted about 12 feet high on ends and 10 foot on sides. Can regular floods or leds. Halogens not the best. Timers and sensitivity a must. What works for you?
ambenz
NW Chicago Suburbs
This is what I just bought...after rebate $80
Brand Name: Patriot Lighting
This LED 8.25 in. white 2-head 240-degree adjustable motion activated flood light is beautifully crafted from aluminium and appointed with frosted diffuser
Color Finish: White
Shade Description: Frosted diffuser
Included Accessories: Mounting Hardware
Number of Bulbs Required: N/A, this fixture contains an integrated LED
Dimensions: 12" W x 8.25" H x 6.25" E
Shipping Dimensions: 13.63 x 9.5 x 7.0
Shipping Weight: 3.3 lbs
They show the lights together in this photo but they do move to any position.
"IT IS Friggin Bright!" As good or better than a incandescent flood...IMO...
Click on this link to see a pdf "cut sheet on this assembly!"
5-YEAR LIMITED WARRANTY:
This Patriot Lighting fixture carries a limited warranty against defects in material or workmanship.
If the Patriot Lighting product fails at any time within five (5) years after the original date of sale due to defects in material or workmanship, return the product to Menards with the original sales receipt.
At its discretion, Patriot Lighting will replace the defective fixture with the same or similar fixture or issue a refund.
Because the base has adjustable switches, I wouldn't want driving rain pounding the base.
I mounted my unit under the eaves on a corner of the garage.
