Need advice on replacing rotted bottom plate
00RT
CT
My 24’x24’ garage has 8’ 2x4 16” on center framed walls with a double 2x4 bottom plate bolted to the concrete slab. Time has taken its toll on the untreated lumber and it is rotted in places. I would like to replace the plate all the way around with new ground contact lumber.
The big thing I need to figure out is how to temporarily support the walls while I do the work. The good news is that everything is stout enough and there’s enough sections still intact that the wall hasn’t sunk, so no lifting will be required.
It’s not really practical to build a temporary wall under the eaves due to the way the ground is. If I build one inside under the ceiling joists I’m afraid that in order to give me room to work it will need to be too far back to be effective.
My plan right now is to take a 10’ long double 2x12 with double 2x12 support “legs” on each end and secure it to the face of the studs about a foot up with 5” GRK structural screws (2 per stud). That will give me access to the plate in between in 8’ sections for replacement. I’ve seen old garages that have been standing for 50 years with a double 2x12 header for a 16’ door on the load bearing wall, so I feel like this should be strong enough for temporary support with no snow load. But, it would be great if others could weigh in, especially if they’ve done something like this.
Bert_
NW Iowa
Did this a couple months ago. Between the doors was easy since there is already a header there. For the rest of it you can place a temporary header near the wall. Work in fairly short sections.
brownbagg
use treated wood.
for extra protected I have always put tar paper between the wood and concrete
BD1
north side
I replaced sill plates be screwing angle iron to face of studs as you were saying with wood. I used 3x3x1/4 angle iron. This provides a nice jacking surface. I used railroad jacks . The bottom foot worked great.
My Old Tools
Hamrick Lake, TX
I did an old garage like that by jacking it up inside, one wall at a time by the top plate. Knock the old one out, get the new one in place, set it back down, toe nail the studs. Work your way around the walls. A few cross braces will keep it from spreading on you.
