graybeardnw
- Joined
- Nov 19, 2024
- Messages
- 3
I have a well pump at my primary residence with the relay box and holding tank in the garage. I just installed an EV charger for my new Volvo which I have set to charge at 35 amps at midnight. I want to disable the well pump from midnight to 6 a.m. to avoid having too much load on the circuit to the garage. I've identified a Shelly 1PM Mini Gen3 smart switch https://www.amazon.com/dp/B0CRRT6HCB?tag=atomicindus08-20 as I read its compatible with my Home Assistance server. The well pump relay box shows the Line 1 and Line 2 leads coming from the well tank pressure switch and my thinking is to intercept the black Line 1 circuit to to Shelly 0 input and SW output. The leads to the well pump show Black Red and Yellow, which of these should I use to power the Shelly? See photo below with my annotation.
Any advice is much appreciated.
