muibubbles
Hey Guys, I need some advice on what to do with my shop floors... A few years back I had a shop fired which destroyed parts of my concrete slab leaving creators in various spots. I've recently finished fixing the patches and I'm about to rent a grinder to clean it up some.
The creators were filled with concrete mix with a skim coat of Portland cement to smooth out the top (probably not the correct way but worked best for me)
My biggest concern is all the dust around the shop- from my understanding I need to treat it with some type of sealer. The shop is 4000square ft and id like to coat about 3000sq ft of it so price is a concern as I'm still rebuilding. I wouldnt mind just a polyurethane? Or concrete sealer except, if its clear you will be able to see all the various patch work (different colors) bleed through. Ideally something with a color or tint so I can make the floors uniform would be best.
Now the catch... I'm about 300' away from a water source and if I wet the floors I don't really have a way to drain out the fluids so a hose/power washer seem to be out of the question for prepping.. Andddd I already have machinery loaded in so I will have to shuffle things around to make it more of a challenge!
I'm not too concerned about hot tire pick up as I can add mats and dont plan on bringing too many cars into my "fab" side of the shop. I was looking into the drylok e1paintbut haven't found many reviews on it... Any suggestions or advice would be great!
Pics are midway repairing the floor, feels good to be able to roll things again!
