Hi...newbie here...purchased a house in central PA that has a detached garage...walls and roof are metal, 50'x30'and 10' high, the inside has 2x4 studs on 24" center and 2x7's for the ceiling. Between the wood frame and metal is some sort of foil bubble type of sheathing and the floor is concrete slab. The previous owner had started to insulate with batt insulation, R13 in the walls. There is no insulation in the ceiling or roof and the soffits are vented.
I would like to finish the insulation but I have some questions
1)Will condensation be an issue if I put batt insulation in the ceiling?
2)Can the walls and ceiling take the weight of sheet rock?
Any advice from the experts will be appreciated. Thanks in advance.
