need an air filter for my DeVillbis Compressor
toplessHO
central florida
I cant believe that such a large expensive compressor has such a rinky dink air cleaner.
Compressor is an 80 gal 2 stage 6.5 HP.
Does anyone make a filter that will take auto air cleaner components?
darkzero
SoCal
I'm not a fan of those filters. My current air compressor had a similar air box & filter. I bought an adapter & put on a Solberg filter.
dogdog
I just wash that foam on mine with dish soap and squeeze and rinse dry.( a craftsman 33 gallon, which happens to be by Devilbliss)
Can't you just cut up some loose felt and line it with your precious N95 mask ?
T
toplessHO
central florida
the foam in there is what I cut to fit
before it had that horsehair type that filtered out birds and large bugs
dogdog
I would try and see if you can buy or make an adapter to retrofit an external filter suggested by DarkZero if it is an 80 gallon 2 stage compressor... There are other companies also makes these intake filters as well... if you don't like Solberg. I have the other one on the shelves in the basement . just never got to buy a big compressor. since I was able to get buy tandem two 33/20 gallons.
