pancholasvegas
- Joined
- Nov 6, 2017
- Messages
- 255
Good Afternoon All,
Reaching out for assistance from the collective -
I've gotten to the stage at my shop where I am in need of my own blast cabinet (Harbor Freight will be the choice). I've been able to get by in the past with using other people's, but I'm ready to get my own.
The issue is that my current compressor is a 24 Gallon, 1.5 Horse, I believe Porter Cable. This has served me well in the past with my LIMITED use of Air Tools, and has been enough for painting smaller parts, motorcycle tanks, etc, but it was definitely at the limits of what the compressor could do.
That being said, outside of the paint gun, I've rarely needed air for tools, but there are some air tools that I would definitely like to add to my setup.
The big question -
Would it be worthwhile to purchase a 2nd Compressor (24 Gallon or so, essentially the same as what I have now), and run these in-series to allow more air? OR do I finally need to step up to something larger, like a 50-60 gallon area?
If the recommendation is to utilize 2 compressors in series, what is the best path forward to do this? Ideally, I'd like to set this up as "Plug and Play," I.e.; I don't want to mess with anything other than turning the power on and hooking up the hose to the tool.
If I need to upgrade the compressor - Are there any recommendations for machinery that comes in under $1,000 or so? Might be asking a lot, but 110 is preferred, if possible. My panel is running low on room since pulling the 220 for the heater.
I believe that I need at least 9 CFM at 90 PSI available, according to the specifications on the blasting cabinet.
Thank you everyone in advance.
The big question -
