I purchased an 80 Gallon lay down tank from Craigslist with what appears to be a Kellog 331tv pump and peerless 5 hp 3ph motor. I intended to use this in my shop but have since found that the previous owner must have droped it and then tried to weld one of the legs back. I have read enough about compromised tanks and decided to purchase another tank.
I picked up an Ingersoll rand tank same size. it came with a 10/15 hp ph3 motor. I have read a little bit about phase conversion or using a vfd but not really sure the cost benefit is worth it. it might be easier just to purchase a 5hp ph1 motor.
Questions:
1. Would it better to use the motor I have (unknown condition even though the last owner said it worked) or just get a ph1 motor and match to pump?
2. do I need a magnetic starter for a ph1 5hp motor (1750 rpm, 184t frame), if so will either of the pictured work?
3. Outside of changing the oil/filter and pre maintenance advice before starting this pump?
Questions:
