SJMaye
I have read several threads and seen many videos on this. I have a twist to it that I think could affect a which sealer I use.
My concrete was poured last year. I did not seal it at the time. I continued with finishing the garage. Since then I noticed that during periods of extended heavy rain I get moisture seepage along the joint between the block walls and slab. The walls were sealed and concrete has 6 mil plastic under it. I guess the moisture is traveling up through the block somehow.
The seepage can be just a darkening of the concrete in several areas along the wall. Or some water even coming up and creating a few small puddles on top of the concrete in the worst case.
I am afraid if I use a topical sealer this moisture will create bubbles or some other issue. Does anyone have a thought?
