So I am looking to do some projects around the house this spring and one is my garage and garage floor.
I have a older ranch style home which at one time had a single garage then expanded to a double garage.
So the garage floor needs some work. For the most part it is in good condition. There are a few level cracks and then the seam between the old pad and new pad when it was expanded to a double car garage.
I've been getting bids from some places that do epoxy floors and I simply cannot afford it - bids were between $1600 to over $2000. I've tried the cans of stuff from Menards and it last all of 12 months before its pealing off.
I am looking to see if there is anything on the market for a DIY that would perform better? I can rent a diamond grinder from a rental shop.
So I am hoping I can find some DIY product that will last a minimum of 5yrs but not break the bank.
You can broadcast the Shark Grip into your wet polyurethane coat, then roll over it on your second pass, if you have enough. This will aid in overall slip resistance.
