The Delta serial number reference on the 'Vintage Machinery' web-site shows your 99- number prefix as late 1950 production.
Its a bit 'fuzzy' in one of the photos, but that one would appear to have either a #2 or #3 Morse taper spindle.
As a practical matter, that is a 'good thing'. Jacobs and Albrecht drill chucks with Morse taper shanks are readily available 'off the shelf'. The Morse taper also.....rather obviously....allows for use of taper shank drills, which are often found cheaply as surplus, in sizes above 1/2".
That model of drill press was equipped with either a single-phase or three-phase motor when new, at the purchaser's option. Most industrial purchasers specified thre- phase.
As mentioned, a three-phase motor can be run from 'dryer plug' residential 230VAC, with a 'phase converter' or 'variable frequency drive'. For use on 115V, one really must have the correct single=phase motor. Ask in the 'metalworking' area of the 'OWWM' aka 'oldwoodworkingmachnes' internet site for dimensional data relative to fitting a Baldor or other make of 115V motor, if a correct single-phase Delta motor cannot be found.
Delta single phase motors are not 'rare' and can be found on the internet, with some looking, but are desirable to Delta collectors, so 'not cheap'. (altho, if one's only investment in a drill press is the cost of a drill chuck and motor, thats a truly excellent 'good deal', a fraction of its value.)
The Delta company made quite a few thousands of that model. Its considered one of the best drill presses for general small shop use, as it is sensitive enough for small drills, but will work up to 5/8" in steel. (actually, up to 1", if one carefully 'step-drills', say, 1/8" larger at a pass)
cheers
Carla
