As all of you are aware, there are some very talented metal fab guys on this board. I however am not one of them. I’m hoping the experts can lead me in the right direction.
Recently, I came up with an idea for a specialty product that is made from aluminum. There are 2 pieces that can be slid together and locked into place using a flat stock locking plate mechanism. I’ve been able to make the main body of the parts and thought I came up with a darn good way to lock and unlock the pieces together but trouble arose. The part I need is roughly 4”x0.375”x0.02”.
What I did to make a sample lock section was order some blue tempered spring steel shim stock. Last night the stuff arrived and I pulled out the tin cutters. Cut the piece to the overall size I needed and fit it into the part. The catch (literally) is I then have to have a tight 90 bend to engage the notch in the part to lock, then another 90 in reverse to act as the trigger to release the two pieces. All was going well until I went to bend the thin metal. It broke! I looked at it, then of course, tried it again. Crack! Well at that point I knew I was working with the wrong material. I then tried to heat it, but all this did was produce stress cracks that broke once cooled.
So now I’m stuck. What thin type of steel should I be using? What type of bending method should I incorporate? I’ll try and figure out how to put a drawing up so you all can see what I’m up against. I think I have a good idea, one which will probably have me outsourcing parts once I bring this to market, so if anyone does this for a living, I’d be willing to talk. Thanks
