Need help about torque wrench
RX-KING
Jakarta, Indonesia
Hi guys, new to me about this snap-on torque wrench, model number is QJMR-210A i buy this tool for 10US$ in NOS condition. i don't know about this torque unit, it's use cmkp instead Nm or lbf/ft:headscrat. anyone know the production date and torque range of this tools. Many thanks for the informations and help:bowdown:;). Sorry for my bad ingglish
crasher98
NW LA
This might be a better converter since in units of torque rather than force:
https://www.convert-measurement-units.com/convert+Kilopond-meter+to+Inch-pounds-force.php
Seems like cm-kp is length x force like ft-lbs or in-lbs (opposite of N-m, i.e., force x length). so you can convert from cm-kp to m-kp (or kp-m) and then use the online converter to get to a more familiar set of units.
But that could be all wrong, I'm not too good w/ the metric system. In the end I ususally get to the point of determining that I either need to multiply by 100 or divide by 100, and then I go watch tv or something.
Ole Slewfoot
Freedom, CA
I do not believe that wrench is big enough for the proposed conversions to be correct.
What I wold do is set that thing to 1000, hook it up opposite an old beam torque wrench, and see where it clicks.
From 500 or 1000, calculating the ratio for conversion should be easy, and cold be used to discover the size of the unit.
Wamsutta
Amarillo, Texas
