Need help. Can't clean fine particles off garage floor!
skuba
Hi all. In the process of cleaning the garage floor, water ended up breaking down some white particles from the foundation wall and I can't get rid of it. It's some material the GC applied to foundation wall years ago, could be just paint, or something else.
I have tried hosing it out, sweeping, and damp microfiber mopping, and there is always some left. Now you can see my shoe prints as well. I haven't tried a proper bristles mop cause I don't have it now, but not sure it would help either.
Any advice?
Thank you
skuba
Floor sweeping compound is what you seek!
Isn’t that sometimes with sand, wouldn’t potentially make a bigger mass?
The material is not fine in the sense of being light and raising. It can’t even get picked by vacuum max suction. So it’s fine but heavy it seems.
Shiftless
East Bay SFO
Based on those pictures, my guess is that you are dealing with the breakdown of calcimine paint. It was popular for cheap paint to cover masonry or plaster ceilings back in the middle 50’s. The stucco portion of our house was painted with that stuff and then quickly repainted with charcoal black latex paint by the flippers that owned the house briefly 2 owners ago. The latex paint was peeling off in huge sheets…like more than one square foot at a time.
I got my hands on a very powerful pressure washer and blew the old white ”paint” off of the stucco and then let it dry for a week. Then primed with a specialty oil based primer with fibers. That was 40 years ago and I have had no trouble since. Not a single square inch of peeling.
To get the residue off of your floor, I would try an acid wash on part of it as a test. Follow the directions. If it IS calcimine paint, the acid will react with the chalk which is calcium carbonate and chemically change it. Just rinse away.
skuba
Thanks for responding. it’s possible. Now that I look at pictures from when I bought the house, the foundation was already painted.
Do you think a strong cleaner might be able to break it down, is that the thinking? You think formula 88 could work? Thanks
skuba
The idea to use something acidic is to try to dissolve this powder on the floor? Cause it's not a stay that I am trying to remove, and sometime the go of harsh cleaners are to remove stains.
skuba
By the way, in case this is relevant. When I got the concrete slab redone I covered with HD40 and burnished.
Shiftless
East Bay SFO
Right. Not a stain to attack with Simple Green or TSP or similar. If the wire dust is indeed broken down calcimine paint, since chalk is CACO3, the diluted HCL will attack that and let you wash it away with water. Do you have a pressure washer?
Run a test spot first. Hydrochloride acid is commonly used to lower the pH of swimming pools. Do you know a guy with a pool? When diluting acid make sure to add acid to water and never pour water on top of strong acid.
Or you can just buy a small container of hydrochloric acid aka Muriatic acid at the hardware store. It is not expensive stuff.
Hank11
Tennessee
Try citric acid first before anything stronger. Easy to find in most groceries. If it works find a cheaper supply of bulk. Its not expensive.
skuba
Have a 1600psi greenworks but motor is running and not increasing the pressure. Something is off unfortunately.
I will try some kind of acid. See if works.
no704
Not sand in my experience, usually some type of fiber, reminds me of pencil shavings. But it has something kind of sticky mixed in with it.
