Rotorhead84
I've survived most of my time as a DIY'er using the cheap-o walmart specials. You know the type, the small square hard plastic digital meters that do basic functions. A few years ago I bought some red thing from Sears (not a craftsman) for like $25 and it has served me well. Again, just used for basic stuff.
I'm "gifting" my current sears meter to the family business because my old man can't seem to ever turn off a multimeter so the walmart special ones we keep there are always dead when I need to use them. My current sears meter has an auto off.
I don't need anything fancy. I was a generator mechanic in the military and while I liked the flukes we were supplied, I don't have any need for something that is several hundred dollars.
Work I do with the meter:
Continuity checks - I need it to beep
Check DC voltage while working on cars/trucks/helicopters 12v/24v
Check automotive fuses
Check resistance across a relay coil (automotive)
Check for presence of AC voltage when working on home electrical projects ( installing lights, outlets, ceiling fans, etc)
Test battery voltage
As you can see I'm not much of a power user.
Features I want: Auto shut off, a hold feature (to take a reading when you can't see the meter and review it later) and I need the continuity to beep.
Thoughts suggestions? While searching the forums and amazon I see that fluke makes a very basic meter. The 101 and 107 for not too much money. They're chinese but anything I'm going to pick up I suspect will be. Are those any good? Also do I need true RMS? I don't really work on circuits.
I would much prefer a USA unit but its not a deal breaker. I plan on buying fluke leads so the quality of included leads matters little.
