candikid
I have made my way into an area where I have absolutely no idea where to start. To keep your interest just a tiny bit longer, I will add some photos of what I need my motor for.
It's a ***** feeder. Pieces of **** will be put into one of its 30 designated trays, and one piece will drop out for every 1/30 revolution of the motor.
I've figured I need at least 40Nm to rotate the carusell when loaded with 30 pieces of ****, so there you have the absolute minimum of torque the motor should produce.
Also a fixed gearing to give me approximately 5-10RPM will be needed.
Power supply is 230V AC, alternatively 3-phase 400V AC.
I really need some help finding a vendor for a motor "like this". You can tell from the pictures it needs to be "flange mount". Yes, I already found one motor (Oriental Motors), but I am afraid it's too weak, with its maximum permissible load of 20Nm.
Thank you all for any interest or suggestions...
