Need help choosing heat 40x60 pole building
Streetglide11
Hollywood, MD
Need some help choosing a heat source. It's a 40x60x15 pole building located in Maryland so we have mild winters. Insulation r40 blown in the ceiling and r19 faced batts in the walls, 2 12x14 insulated doors, 6 double hung windows and one man door. My 2 heating options are wood furnace or hanging 125,000 btu heater. I will mostly be using the shop nights and weekends the doors will stay shut most of the time not constantly opening and closing. Only looking to keep the temp comfortable to me that's 50's maybe 60 at most. I have 16 acres with plenty of wood to supply a wood furnace but there will be a few day a week I wouldn't not be able to feed a wood stove. So I was leaning towards hanging propane heater but I'm not sure how much propane would cost to keep the shop at 50 all the time. Propane is around 3.14 gal delivered. Already spoke with insurance company I can have a wood furnace so that's a non issue. Anyone have a shop my size using wood or propane with input would be great.
Krzewinskibe
Northeastern Maryland
I have 48x44x14 with 150K propane and it heats fine...even without much insulation on the walls yet (I'm working on insulating)
Also in MD. You might want to shop around for propane...I just paid $1.659 last week.
finn
The UP, God's country
I’m using a 75k to heat a 32x75’ area of my shop with 16’ ceilings.
It’ s been in the single digits outside this week, and it gets the shop up to 65 from an overnight setting in the low 40s with no problem.
We don’t have mild winters.
astroracer
Mid_Michigan
I use a NG forced air house furnace in my shop. It is 6 degrees in MI. right now and my shop is 52. I leave it there unless I am going to be out there all day like on the weekend.
Wood is a lot more work intensive, dirty and inconsistent then a set the thermostat and forget it propane or NG furnace. Your choice I guess.
Mark
Rob7181
Where are you guys in Maryland? I am just west of Laplata.
I have a 40x104x18 building I am getting ready to put three 3 ton mini’s splits in.
Repsolracer22
central MD
I have virtually the exact same setup. And I'm also in MD. I did a Reznor 125k. Best move I ever made. Most efficient heater on market. And it's compact compared to Modine units. I bought a 100gal propane tank from gas company. They sell me propane for $1.29/gal delivered. I keep mine at the same temp you are talking about and use my building in the same manner you're describing. Last year was the first full winter with heater. They refilled me once. So I didn't even go through 2 tanks of propane. Couple hundred bucks and kept entire garage perfect all through the cold months. I have diesel stuff, sideXsides, motorcycles etc etc that I like to keep at 50-55 deg. That's all I need. And if I want to go in there and hang on the couch and watch a game or something, I'll kick it up to 64 or something and it's warm fast. The best place to get these heater from is a site called Total Home Supply. They ship out of jersey so MD gets quick delivery. Free shipping. Reznor UDAP 125k, quick sling mount kit, propane conversion kit, and horizontal exhaust pipe kit. Total is like $1300 roughly. Maybe $1400. Great deal, awesome unit. I recommend horizontal exhaust out side wall instead of ceiling. Cutting holes in ceiling is always much riskier. I just piped out the back corner side wall. I have a $20 thermostat on the wall to control it.
Now I'm adding onto my 40x60. Being built now. Since the 125kbtu by everyone's calculations is a bit oversized for a 40x60, I'm just going to cut a 9x9 hole in the wall for a walk through to the new side and let the heater heat that too! I debated on heating the new portion separately but my current 100gal tank doesn't have the pressure to supply 2 heaters. So I'd have to buy yet another propane tank for the new heater and it was overkill I think. So we'll see how the 125k works for heating the new 30x40x16 in addition to the existing 40x60x12.
I too did r40 blown in attic and then r19 in walls. I finished the walls w bright white metal. LED lights from sams and a couple 80" fans from Home Depot on ceiling.
By the way, I have some land too and essentially free wood for life. I seriously considered the woodstove thing too but just wasn't practical as you always have to keep adding wood. And good quality big output wood stoves are $5000 installed easily.
Streetglide11
Hollywood, MD
Thanks for your input I appreciate it. I actually picked up a wood furnace and all the piping to hook it up for 400$ so I'm going to try the wood and see how it goes worst case is I resell if it can't keep up.
