Need Help Cleaning Car Carpet
rcbk00
I'm having trouble getting some stains out of a beige automotive carpet. I don't know what they were from, but it looks like coffee or hot chocolate (courtesy of the prior owner). I've been pretty successful with Tuff Stuff foaming cleaner on the rest of the carpet, but there's two spots that are being really stubborn (I've foamed and scrubbed multiple times). I'm not a professional detailer, so I don't have an extractor vacuum. Are there any products out there that might be better than what I'm using?
RAYJAY
UNION DALE PA
get really good carpet shampoo hot water and a wet shop vac, you can even try some APC on the stains ( do try a test spot undr seat or wera it can not be seen first) i persomal will soak the spot get it really wet and then scrub with a good stiff crubbing brush
stonesfan68
Houston, TX
I rented a carpet cleaner from HD a couple of years ago when I had a similar situation. The hot water really helped to lift the stains out of the carpet.
dfiler2
NW Minnesota
I have had the best luck using just very hot water, keep in mind carpets are just small strands of plastic.
unslow1
Illinois
Sprayway glass cleaner took stains out of my cars that had been there for years. It works much better than any carpet cleaner I've tried.
unslow1
Illinois
I read somewhere on this forum that Gumout starter fluid cleans fabric really well. Haven’t tried it myself yet.
I'm sure it does. WD40 does a great job too but good luck getting the smell out with either. That would be one of those how bad do I want this stain out questions.
Old Man Roger
Palm Coast Florida
Back when I used to work on trash trucks, winter time meant we used ether like it was water. The smell dissipates reasonably fast, but I didn't go around sniffing air cleaners either..lol So you may be right.
zeke67
Houston
Been there. Tuff Stuff is pretty good. The Blue Coral product is too. If you ca't get the stain out or it keeps coming back it is likely that whatever it is is soaked thoroughly in. The best idea is what's been posted, pull the carpet and pressure wash it.
Bretny
Dutchess county NY
I recently cleaned a well neglected smoker's car that I bought for very cheap. I used a carpet cleaner hand wand but it be honest a shop vac would work just the same. I used "spray nine" and a drill brush. It did take many runs at it but I highly doubt this car was cleaned in 20yrs.
Even the headliner needed to be cleaned.
charbar
Midwest
Has anyone tried this Spot Shot on headliners? Previous owner of my Tahoe must have had a family of 5 living in it and the interior was disgusting. Even a hot power washer and Oxy Clean wouldn't touch the carpet so I ended up dying it black :lol: Got everything cleaned up good but the headliner still needs some work.
scottmoyer
Central FL
Depends on the vehicle, but it may be a better choice, and less hassle, to just replace the carpet. You get a fresh interior, new car smell and you don't need to worry about what that stain was. I've seen some carpets for as low as $200.
sreeb
SoCal
This is potentially a lot of work. Even compared to removal and powerwashing.
scottmoyer
Central FL
How so? If you're removing it and power washing it, wouldn't it be easier to install the new carpet instead of reinstalling the old washed carpet?
sreeb
SoCal
Have you installed many new carpets? Especially the cheapest possible carpets?
It is common for the aftermarket ones to require some fitting and cutting of holes. Some of them are better molded than others. Some cars and carpet designs will be easier than others.
It could be a 10 minute job but it could also be a lot harder.
4xdog
Santa Fe, NM
...The Blue Coral product is too...
I've had great luck with Blue Coral. The stuff's amazing.
Pressure washing indeed works beautifully. There's all kinds of dirt in an automotive carpet that will come out that way. Wash it on a sloping part of your drive and it'll self-drain pretty efficently.
peterp
Old thread, but the best carpet cleaner I've seen by far is Folex (https://www.homedepot.com/p/Folex-3...MWEu8z1VTdejEg9YqWhoC42YQAvD_BwE&gclsrc=aw.ds).
It's cheap, available off the shelf from Home Depot, and (unlike Blue Coral and everything else) it has no smell at all -- but it's a highly effective carpet cleaner. I can't recommend Folex more highly -- I don't know how it cleans so well without the smell of chemicals, but it gets the job done.
noel4747
Chemical Guys Lightning Fast cleaner has never failed me along with the drill brush attachment
mikedodge
Using a carpet extractor or at least a wet vac works great on getting stuff out. Spray on wipe off doesn't do much for heavier stains.
Depending on how old the car is taking it out and pressure hosing it down can be a bad idea. Depending on what kind of car it is a lot of newer cars have thick molded foam on the back instead of having under padding like cars used to and that stuff can take days to dry out.
Benw455
WV
I normally use Simple Green with hot water a stiff brush and a shop vac. Always works for me, and it smells good.
