Need help--Depth Micrometer
garthg
Winchester MA
I bought a new-to-me Starrett depth micrometer on ebay for use in re-shimming BMW motorcycle transmission bearings. I've never used a depth micrometer before.
Using it, zeroing it out and changing the depth rods seem obvious enough. But it came with some other parts the uses for which I have no idea. There are some small rods that look like nails, a spring, a set screw and another steel rod with a turned end. I don't know if these were for some specific purpose of the former owner, or if they're part of the micrometer set.
If anyone know, please advise. Thanks.
(Sorry for the giant phone pics, but the parts are very visible.)
DenisG
Milwaukee
I believe that the top knurled end cap unscrews to allow you to exchange the different depth rods provided in their sets.
KMScott
Your Depth Mic is a blade depth Mic but you know that, it is missing one blade since most come with three blades. 0 to 1 inch, 1 to 2 inch and 2 to 3 inch. The three pins ( Die Maker pins) and the rest of the stuff are not parts for your Depth mic. Some times older depth micrometers had small shims that nest against the shoulder to make up for small errors in rod lengths.
G
garthg
Winchester MA
Thanks. I have all three rods. Just not shown in picture.
davethorik
Norka, Ohio
I love depth mics I sort of have a problem. I have 4 sets. Lufkin 0-6, Lufkin 0-6 blade depth mics, Lufkin 0-3 with graduated 5" base, and Starrett 449 identical to yours.
The Starrett are my beaters but the Lufkin sets all have 4" or 5" bases, sometimes a narrow 2.5" base is nice. I got my 0-3 set for $20 but they're in rough shape. Plier marks. Worn threads, luckily there is an adjustment. The blade keeper doesn't work so the blades spin just like a regular depth mic unless you hold the blade still. Between these and the Lufkin blade depth mics I use them probably more than the rod style.
G
garthg
Winchester MA
Thanks. I didn't really know the difference, but I think the blade mic will be fine for my purposes. And I think it will be more than accurate enough for my purposes. I paid $23.
Also, since I'll be measuring differentials, it doesn't really matter for my purposes whether it zero's out accurately (although I think it does).
ttpete
Dearborn, MI
You might want to check the 2 and 3 inch rods. All it takes is a known good 123 block and a flat surface. They should be adjustable.
G
garthg
Winchester MA
The rods are not individually adjustable, but the mic is. I do have the adjustment wrench.
Since I'm only going to be measuring the difference between bearing height and recess depth, I think the absolute number on the mic is not critical.
But thanks for your response.
A_Pmech
IL
Those are likely shop brew rods to check a feature too small for the standard size rod.
