428street
Hopefully someone can help with the problem I am having with my old SA AC. Thank you in advance.
A little history. I bought this from a friend of mine who upgraded his system about 15-20 years ago. I think he had it 10 years before me. I think it's a decent compressor (in it's day).
Recently he helped me replace a valve that goes from the tank to the top of the cylinder head on the engine. Don't remember the exact name of the part but I know it was some type of stop valve because the tank stopped holding air and there was a hissing sound coming from that tube area. This was replaced and the compressor has worked fine. I use it very rarely but as I am getting into doing body work and metal shaping I have bought some new air tools and started using it more.
The most recent problem is I went into my garage one random night and it was smokey. The compressor was on as it kicks on every once in a while to maintain tank pressor.
I walked over to the compressor and the top of the engine was smoking. I put my hand on the top of the cyclinder head and it was hot. It was not red hot but hot to the touch. I immediately turned the master power switch off that I have it connected too, open the garage door to let the smoke and and called it a day.
I then started looking for another compressor to replace this one but found out they are not cheap. So know I am searching for some help/direction in solving this problem and/or fixing the unit I have.
A couple days ago I put the compressor back on and filled up the tires on a couple of my vehicle and my snow blower and it was fine. The top did get warm but not as hot as it was when I initially encountered the problem.
BTW, my friend that has helped me in the past has become ill and can't help me anymore.
Any help, direction, advice would be appreciated. Good or bad. Thank you.
