Need help drilling deadbolt lock hole
23ford
Turley America
Bought a steel door from Lowes that has a hole in it for the handle but not the deadbolt lock. How high above the handle do i drill the hole for the deadbolt?
DCarr2
Akron NY
You could add extra level of security, drill a deadbolt hole in the top corner, and bottom corner...
Hot Rod Grampa
Near Cooperstown New York
Is there enough wood to drill the extra hole? I was told that the metal doors do not have a thick perimeter wood frame and there wasn't enough meat to drill additional holes. The doors pre drilled with 2 holes have a different frame. Maybe I was told wrong. Just thinking out loud.
58Yeoman
Central IL
I've lived here for 9 years, and this year I noticed that the steel door on my shop had a hole for the dead lock bolt, but not a hole in the metal for the lock. Easy peasie to see where to drill the hole for me.
archirelic
texas
there is always blocking for deadbolt preps. I say always cause I have never run across one that didn't
That's not always the case I've seen. If it's a simple "utility" steel door, then it only has the blocking for the handle, which is a predrilled hole. Many steel utility doors don't have blocking to accommodate a deadbolt...that's why they sell exterior steel doors with both holes already prepped.
nut_buster2017
Sometime ago, a client needed a deadbolt in a residential steel-skinned door which was not intended to have a deadbolt, so no blocking.
I made a jig with hardwood and was able to drill it out for him; there was maybe 1/16 inch wood left on each side of the of the stile.
Not really effective, should someone have decided to give it a good boot, but presumably enough of a deterrent to make them think twice.
Zeke
IDK if the OP's door has the blocking or no, but after locating the hole and drilling a pilot from layout marks on both sides (don't forget the bevel if there is one) and then drilling out the main hole with a hole saw, you can slip some blocking up inside using some fast glue or bondo. If it protrudes into the new hole, touch it up with the HS. Might heed a predrilled guide with no pilot.
If the edge is not wood that's where the fun begins making a depression for the bolt latch. It can be done with a pair of pliers and a cold chisel. There is little force laterally.
