exranger06
I'm installing a 90 amp subpanel in my attached garage. I'm not sure what the best way to get the wire from the main panel to the subpanel is. I have attached pictures to show where the wire needs to go. I was planning on using 2-2-2-4 SER Al, unless someone has another suggestion for wire. The main panel is located in my finished basement, right next to a hearth for a wood stove:
I may or may not actually install a wood stove in the future. As far as I can tell, there has never been a wood stove installed since the house was new, even though the hearth is there. The other side of this wall behind the main panel and the hearth is the exterior of the house obviously, but to the left of the hearth, on the other side of the wall is the garage. So to get the wire into the garage, I would need to run the wire inside the wall to the left, behind the hearth, then through the wall into the garage.
This is the other side of the wall. The main panel is of course right behind the meter on the other side of the wall, and you can see the unfinished wood stove pipe coming through the wall. The adjacent wall where the AC condenser is mounted is the side of the garage.
And this is inside the garage. On the other side of the finished wall is the basement, and the unfinished wall is the exterior wall where the AC condenser is right on the other side.
I would like to mount the subpanel right in this corner on the unfinished wall.
What would be the best or easiest way to get the wire into the garage? Should I try to go behind the hearth? What's the minimum distance the wire has to be from the chimney? Or should I just run a conduit on the outside of the house and through the side wall of the garage, since it's a short run anyway?
