Need help finding a router bit
milwaukeephil
New Berlin
Hi All
Can anybody give me a name or tell me where I can buy a bit like this?
I'm working on a new product for my company and one of the components is vac formed. I need to have a flange around the edge, just like in the photo below, of about 3/8" (these are screenshots from a youtube video).
My searches turn up flush cutting bits with a bearing on the end, but none with a larger diameter bearing than the cutter.
Thanks!
lardy1
We called them oversized bits when I worked in the cabinet shop. Some bits can accept different sized bearings.
manwithtools
Lebanon, TN
Yes, you can buy bearings of many diameters. You will likely have to buy the bit and an oversize bearing separately. Try Whiteside or CMT. Look for a 1/4" flush trim bit and then a 1" diameter bearing. Or a 3/8" and a 1-1/8" bearing".
milwaukeephil
New Berlin
Guys, thanks for all the help. I have a lot of new info to research.
This place is awesome. I'm smarter now then when I woke up this morning.
PCustoms
VT
Successful day!
I'd find exactly what you want, but Comcast has an outage and my cell barely gets data in the house.
I did just go down and dig though my random bits drawer and put a 3/4" bearing on a 1/2" straight cut, can't upload pic though. I've built some weird combo over the years for similar tasks (composite trimming), you've just got to find who has the right combo. My typical go to was Whiteside
PCustoms
VT
Also just remembered another trick to get larger offsets. Get a bit with a 1/2" OD guide bearing, and install a "standard" 1/2" ID bearing.
In my cheaper days I've made a lot of custom square guides out of barstock using this method.
milwaukeephil
New Berlin
Smart. You're talking about a press fit?
milwaukeephil
New Berlin
Another question. The parts are an 18" diameter circle and a 20x6" rectangle. Will a larger OD cutter work faster or should I keep it small?
PCustoms
VT
How thick is the material?
Generally a smaller diameter will cut faster, but it's a balance of rpm and feedrate, which is going to tie back to stiffness of the bit and router power.
Also, are you cutting those in the form still? If so, can you make the offset into the form, and then just use a flush trim?
milwaukeephil
New Berlin
Also, are you cutting those in the form still? If so, can you make the offer into the form, and then just use a flush trim?
Not sure on thickness yet... less than 1/8".
Not cutting them in the form. I'm gonna have a router table setup right next to the former.
