hondacivic247
- Joined
- Sep 15, 2014
- Messages
- 538
So i picked up a quincy 325 roc 100, I ran it today and herd all sorts of funky noises so I pulled the valves and have a few issues from the previous owner doing valve work 6 years ago.
First off this isn't a constant run model only have one unloading tower on the high pressure side. Now on the lower pressure side opposite the unloading tower I pulled the valve and I think it's missing then 3 steel rods and springs that go in the 3 holes in the valve assembly? When I pulled the unloading tower that valve assembly had the 3 rods and springs, or does this side not need them sense it doesn't unload ?
2nd issue the high pressure side and low pressure side opposite the unloading tower beleive there called discharge? Well the bolt and the bottom disc on the valve are both smooth as a baby's *** the bolt slid right into my hand when I pulled on it. My question here is what is the bottom valve disc thingy called or can anyone relay a part # for both the HP/LP sides need the disc and bolt only.
Everything else in the valves looked good the head had a little rust inside which I cleaned up the best I could.
