toadjammer
I just bought a 4 post lift and need to know what brand or a similar brand so that I am sure to assemble it correctly. Briefly it is black with white brackets at the top of the posts and white ramp and attaching brackets. It has round locking holes and pins that are spring loaded to automatically engage as the lift is moved up. The runner supports have a larger square tube that goes all the way around the posts with plastic rollers that are each on a piece of round stock that is welded on each end at the top and bottom of the tubes. The pump unit is mounted on the outside of one of the posts with angle iron at the bottom and thetop support, not directly to the side of the post.
Thanks for any help.
