Need help on cutting brick
wren57
Hi all. I'm changing an exterior light from one with a round base to one with a square base. As such, I need to trim the brick to more of a square, almost all the way up to the mortar line. Should I just use a chisel and punch vertically along the left edge and hope the brick breaks apart? The red box indicates the size of the new base.
(couldn't find one with a round base that looks right)
rayra
Escaped from Los Angeles
I would not, likely to break / crack where you don't want it to. I'd use a 1/8" masonry drill to drill the corners then I'd use a small angle grinder and masonry disc and I'd cut in the outline. This will give you clean edges at the surface. Then a very small chisel to tap out what remains inside your corners. With as little force as possible.
W
wren57
You guys are awesome. I do have a milwaukee multi-tool, will get a masonry attachment. THANKS!
PoorUB
Fargo, ND
I would be tempted to take a piece of PVC trim board and shim out the lower instead of trying to cut out the upper brick.
engineer2
Chicago burbs
Most fixtures are surface mount. I would just cut away the raised portion of the brick.
Get a good quality diamond blade for you oscillating tool.
I got a cheap one and within 5 minutes the diamonds on the edge were gone.
rsanter
visalia ca
I would make an adapter piece that compensated for the step in the brick and also adapted the hole pattern as needed
Bert_
NW Iowa
I like this thought. Paint it a brown that matches the brick.
Problem with cutting away the brick is what happens when you want to change the light to one with a smaller canopy. You will have a hard time repairing the damage some day in the future.
Box really should have been placed lower so it didn't interfere with that ledge but it's already done.
W
wren57
Tha masons should have a clue and set the brick at one level!
lol, it's a design feature. I used my grinder then got the carbide diamond blade for my oscillating tool as suggested. Worked like a charm! Thanks again everyone.
