Need help on metric socket size
bdog
I am working on a Japanese piece of heavy equipment. All the fasteners are metric. I have some bolts I need to remove that are very tight and I am going to have to hit them with the 1” impact.
I have limited metric tools in larger sizes. A 1-3/4” wrench won’t fit, I don’t have a 1-13/16” to try, a 1-7/8” fits and feels fairly tight but with a four foot cheater it starts trying to round the nut.
I need to buy a 1” drive socket in the morning. I am tempted to try a 1-13/16” it I know it is metric I just haven’t a clue what size to try.
Cruzan80
Denver, CO
Well when converting, 1 13/16 works out to almost exactly 46mm. A 1 7/8 is 47.625mm. So when you say it is tight-ish on the 1 7/8, is it less than a mm tight, or more like 1.5mm tight?
Sorry, dont know if 46 and/or 47mm are a standard head size, just did some quick math.
Sent from my Phone 2 using The Garage Journal mobile app
davethorik
Norka, Ohio
A simple google search will turn up the formula for converting metric to inch, and vice versa.
WittHay
Surrey, BC Canada
M30 bolts are 46mm. Actually have a 46mm 3/4" drive impact socket
1 1/8" bolts/nuts are usually 1 11/16" socket size and 1 1/4" thread size is 1 7/8" socket
timgunn1962
Lancashire, England
The standard Metric sizes are
M4 7mm
M5 8mm
M6 10mm
M8 13mm
M10 17mm
M12 19mm
M16 24mm
M20 30mm
M24 36mm
M27 41mm
M30 46mm
These are the common preferred sizes for off-the-shelf fasteners. Obviously there are other head sizes used in many automotive applications and the like. There are also other thread sizes which are less common.
Caveat: these are apparently the DIN standard sizes (Deutsche Institut fur Normen: German Industrial Standards) and effectively the standard in Europe. The ISO standard heads are smaller on the M10 and M12, at 16mm and 18mm respectively.
steveo3002
cambridge england
M4 7mm
M5 8mm
M6 10mm
M8 13mm
M10 17mm
M12 19mm
M16 24mm
M20 30mm
M24 36mm
M27 41mm
M30 46mm
dont our freinds from japan prefer 12mm/14mm heads?
be easier to just ask...anyone got a *** car , what size is the bolt on the xyz
Samuel D
A fair degree of play is fine with Flank Drive-style sockets.
That’s the great merit of the design: it increases the contact area greatly (after elastic distortion of tool and fastener) at the expense of a slightly worse contact location (the flanks of the fastener, even near the corners, are at a smaller radius than the corners).
I have some Wera Hex-Plus Allen keys that do the same trick in reverse. They have a slacker fit than many other Allen keys but can take more torque without plastically (permanently) deforming the fastener.
Dave455
Sussex, England
Folks, there are many different metric standards, not just one.
The common ones are ISO (theoretically International, but most commonly used in the U.K) DIN, (German, supposedly being replaced by ISO, but don’t hold your breath) ANSI (American), and JIS (Japanese)
If it’s Japanese equipment then it will be a JIS size, so, the ISO and DIN sizes quoted are correct, but not relevant.
I don’t have a table of JIS sizes that large, but I do notice that my Koken catalogue lists both 46 AND 47 mm sockets, so I’m thinking it could be either.
Only way to proceed, especially if spending serious $$$ on an inch drive socket, is to measure it!
alfazer
N. Ireland
I live in metric land and do encounter 46mm from time to time. The most regular encounter is the single rear wheel nut on my 2013 Triumph motorcycle.
I've never seen a 47mm.
cherrybomb
Near Madison Wi.
I would venture to say 46mm.Any time Iam in doubt of a size,I get out my digital caliper,I can put it in metric mode,read the size,flip over to S.A.E.read the size. I also have a large chart with all the equivalents on the wall.Hope this helps.
The hack way out, can you jam something stout between the nut and socket to close the gap? Chunks of feeler gauge, Allen wrenches, etc to make it fit. Not sure what would best close the gap and withstand the impact.
I’ve used two small Allen wrenches to replace an unavailable oddball large one in the past, but never with sockets or impacts.
DFB
Southern VT/Western Mass
Using a 1 7/8 is about 1/16" or 1.629mm over sized for a 46mm
I used a 1 3/4" on a 43MM axle nut before (1.45mm oversized) ya felt loose but did the job really with no ill effects
Dave455
Sussex, England
There's no such thing as 47mm. After 46mm, it goes up incrementally by 5mm, so 50/55/60/65, etc.
There may not be in some standards, but there obviously is in at least one.
Here’s an extract from the Koken catalogue showing a 47mm socket!
measuredtwice
USA
OP, can you measure it? If you can't reach it with a caliper or ruler, use the ruler to draw 46 and 47mm marks on a scrap of paper and tape the paper to your socket extension.
driz
Northern NY
Yep, hardly a day goes by I don’t whip my trusty $10 ( on sale) HF electronic caliper. I just can’t say enough good things about that little gem.
T anyone looking for one be aware they sell 2 styles. One doesn’t button through fractional, metric and thousandths. The Gray one with 3 gray buttons is the one to get. I’m always setting mine on whatever bolt ect . Then carefully sliding it back and forth till it lands on the closest size that makes sense. Great for sizing drills, holes, sheet metal thickness ect.... and still cheap enough not to cry if it gets dropped.
Junkdrawer Dog
LV NV
141me.jpgI used one similar to this at work. Approximately $10, light enough to carry in shirt pocket. Not meant for precision work but plenty accurate enough to size nuts, bolts, holes, etc.. Works up to 75mm/3inch, inside and outside.
bdog
Thanks guys. I don't have digital calipers but will buy some. It is kind of a long story but where we are working is about an hour round trip drive to the store that will have sockets this big, or the calipers for that matter. It is hard for us to break away during the hours they are open right now as we are slammed trying to get everything ready for a job next week. I bet it is a 46 mm. We got side tracked on another project today and didn't even get a chance to mess with it.
Rabid Badger
1 inch is precisely 25.4 millimeters.
1-13/16 x 25.4 = 46.0375 millimeters.
Buy a 46mm socket.
