need help on solar ground mount
Kaizen
New England
I am doing ground mount solar panels on one side of my yard. I wanted to try to make an adjustable single mount 6 panel set up with steel I had on hand and now have a bending issue. I used 1.5" 1/8 wall tube with a center pivot on the post as shown in picture. I used factory made aluminum rails bolted to these to secure the panels. I ran a string line after loading the 6 panels and have too much deflection to be comfortable with. I have a front stabilizer bar running from the front to the center post to keep it all from moving as it is perfectly balanced and swings easily to change for the seasons.
I can jack it straight and weld something to the bottom or the side OR I can try and make an upside down truss of some sort. these end bars are 12' long and i'm wondering if any one with more structural experience can make a suggestion. How far out to go....what size....etc?
Or any other ideas would be great.
GeoBruin
If you're set on using the 1.5" tubing, you'll have to stiffen it somehow. A truss is a cool idea but probably not necessary. I was going to suggest skip welding a piece of flat bar to the bottom of the member, but I realize you've bolted through it. How about welding a piece a angle iron to the back of it so you can still bolt through it, but it adds some stiffness?
jeepxj
6" height in the middle. taper down. critically move the pivot point to the bottom putting the top member into tension.
K
Kaizen
New England
Beautiful. The pivot point was what i was worried about. Too much weight to move safely at this point so i'd have to take it all apart. Not sure i could fab this up in the air. I appreaicate the help and viaualization.
K
Kaizen
New England
I was eying my scrap angle pile with this thought. I would need to go to the metal store and if i'm doing that maybe just get the 2.5" tube and do it right. arghhhh. Angle sure would give it 2x more stiffness. gotta ponder. ty
jeepxj
no you'll need to pull it down.
if you want to fab in the air i'd prefab the truss on the ground then use some bolted connections at the end to be able to bolt it up before welding while pre tensioning/pushing straight the main spar
jeepxj
You could just slap another 1.5" box tube you seem to have plenty of on the bottom after you straighten the top piece out. giving you a 1.5 x 3" effective tube.
K
Kaizen
New England
Yea definitely would give it the needed strength. Should have just bought 2x4 tube and saved myself the trouble. Thanks for the guidance.
larry_g
oregon
in my minds eye you could fabricate something like this that would have a U channel on below the pivot to support the tube for a foot or so between the two mounting bolts for the panels. I'm assuming that most of the bending is happening where the tube is weakened by the drilled pivot hole. 1764345772686.png1764345772686.png
K
Kaizen
New England
That would be a nice seasonal adjustment bracket. At 12 feet long my guess i'd need support for at least the middle six feet. Think its just too much of a load. Of course the 3/4 hole didnt help the situation but its an even bend the whole way. I might add something like this regardless to strenthen that hole. in hindsight that was a dumb move.
