mitchn06
Picked up this guy the other day for $75. pressures up to 125 or so just fine, turns back on at 80 or so no problem there. i'm not too familiar with air compressor terminology, but i'm learning. the problem i have run into is that after about the 4th or fifth cycle, it has started leaking out of the intake and out of the crank when the oil fill dipstick is out. the filter that was on it when i got it is not worth mentioning. I did remove the top valve covers and discovered that it was nasty inside due to the lack of filtering. i cleaned it the best i could.
from what i have read i have a bad or leaking reed valve. i suspected dirt build up, that is why i removed the covers and cleaned. it was the low pressure that was dirty, the high pressure was fine. I did come across this site http://www.aircompeq.com/ka.htm but that is about it. i can get some pictures up tomorrow if it helps. Thanks
Its no wonder the crankcase is hissing….
