Welders supply, a local supplier by me has a closeout on the 180 MILLER with free shipping. GREAT DEAL ! $ 649.00
http://www.weldersupply.com/P/1081/Millermatic180AutoSet907
Product Number: 907312Product SKU: 907312DIMENSIONS
Height: 15.30 Inches
Width: 10.50 Inches
Length: 17.10 Inches
Weight: 72 Lb(s) 0 Oz
$649.00
Millermatic 180 AutoSet #907312
**CLOSE-OUT SALE***
Light Industrial Applications:
Light Fabrication
Maintenance and Repair
Auto Body
Farm/Home
Processes:
Mig (GMAW)
Flux Cord (FCAW)
Input Power: 230V, 21.7A, 60Hz, Single-Phase
Rated Output: 135A at 22.5VDC, 30% Duty Cycle
Max. Open-Circuit Voltage: 31
Auto-Set TM: The right settings automatically.
Set the wire diameter, a blue light shows that Auto-SetTM is activated
Dial in the thickness of what you’re welding
Start welding with the exact parameters you need!
Infinite voltage control gives you the flexibility to manually set the machine when welding aluminum, stainless steel, or anytime you want to set your own parameters on mild steel.
Welds thickest material in its class! The Millermatic® 180 Auto-SetTM has the highest output in its class. It can weldfrom24ga–5/16in(0.8–7.9mm) mild steel in a single pass.
Spool gun compatible! Finally a reliable and economic way to weld aluminum. Hooked up to a Millermatic® 180 Auto-Set TM, the Spoolmate 100 Series spool gun allows you to weld from 18 ga – 1/4 in aluminum.
Smooth-Start TM provides a smooth, spatter-free start. It’s the best-starting machine in the small MIG machine category. No pop gun starts and no spatter to clean up.
Durable cast-aluminum drive system
incorporates dual-groove quick-change drive roll and spring-loaded tension arm with calibrated tension knob, all designed to make set up easier and faster.
Thermal overload protection shuts down unit and activates over temperature light if airflow is blocked or duty cycle is exceeded. Automatically resets when fault is corrected and unit cools.
Comes Complete With:
Power source
6 ft (1.8 m) power cord and plug
10 ft (3 m) M-100 MIG gun and cable assembly 10 ft (3 m) work cable and clamp
Smith® Argon and AR/CO2 mix regulator/flow gauge with hose
Spool of Hobart® .030 in (0.8 mm) solid wire Two contact tips for .024 in (0.6 mm) wire and two contact tips for .030 in (0.8 mm) wire Dual-groove quick-change drive roll for .024 in (0.6 mm) or .030/.035 in (0.8/0.9 mm) wire Factory-installed gas
solenoid valve
Set-up and operation CD
Information/settings chart
Material thickness gauge #229895
Note: Shielding gas and safety equipment not included
Easy access to output studs provides convenient polarity changeover when changing from solid or flux cored wires.
Miller’s “Tip Saver” short circuit protection shuts down output when tip is shorted to the work. Extends contact tip life and protects internal components from damage. Trigger reset permits quick reset at torch rather than unit.
Standard built-in solid-state contactor circuit makes wire electrically “cold” until trigger is pulled, making the unit safer. It’s also easier to position torch to work before starting weld.
Uses4or8in(102or203mm) spools and can be set up to weld with wire sizes .024–.035 in (0.6–0.9 mm) mild/stainless steel and .030 – .045 in (0.8 – 1.2 mm) flux cored.
