need help reznor V3 making vibration noise when fan kicks on
Jwestercamp
So i have a Reznor V3 and wouldn't you know it, that it decides now would be a good time to start vibrating. Only happen when fan kicks on. I have replaced the motor, and it got a bit better, but i think i might have a bent blade. Took blades off and bolted it back up, still makes some noise but not as bad, Found out that the blade is balanced, any thoughts? Thanks GJ!!!:confused:
